juicersr's Avatar
One more twin plug question.....
Just trying to understand why 12 points are needed for a twin-plug dizzy. If the plugs are fired nearly simulataneously (a recent thread discussed this i think) for each indivdual cylinder for efficient combustion burn, why can't you run two wires (a split wire set-up or something) from the same point? Probably a dumb question, but i couldn't find the answer from past threads. TIA
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 12-17-2005, 06:46 AM
Irrationally exuberant
ChrisBennet's Avatar
It's not a stupid question. The reason you can't run two wires is that electricity will always follow the path of least resistance. Only one of the spark plugs would fire if you used some sort of "Y" connection.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-17-2005, 06:55 AM
juicersr's Avatar
Thanks Chris, knew there was a simple answer that i was overlooking.... forgot my ohms law or whatever from physics 101.
dzugautomobili.com
Old 12-17-2005, 07:00 AM
Send a message via Yahoo to Lukesportsman
That is why many argue that Split Fire plugs may help fouling, but can't make more power.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 12-17-2005, 07:07 AM
The multi point plugs only have one spark path (at a time) but as the resistance of the current path increases the path switches to another prong. Bosch has something similar also. The SplitFires are just plain junk (crappy insulator, etc).
-Chris
Old 12-17-2005, 07:16 AM
