3.2 service intervals
Does anyone know what is involved in the 60,000 mile service interval for a carrera 3.2?
I see some cars being sold with this recently being done. Is this just a valve adjustment/fluid change?
Old 03-17-2008, 06:45 AM
Barrpete's Avatar
From the table in my owners manual:
Oil & Filter
Valve Clearance
V-belt & Polyrib belt
replace spark plugs
Replace engine air filter
Replace fuel filter
Replace Oxygen sensor
Inspect for leaks
Crankcase ventilation system check
Intake air hoses inspection
Check brake pads, pedal & system (fluid)
Clutch adjustment
Steering gear, ball joints, tie rod ends
Wheel Bearings
Drive shafts inspection
Lube clutch release lever and spring
Transmission for leaks
Exhaust system visual inspection
Tires
Throttle actuator
AC system
Transmission oil
Check fuel system for leaks
Parking brake adjustment
Headlight Adjustment
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 03-17-2008, 07:29 AM
I have also wondered about service intervals for the Carrera.
The major one is supposed to be at 15k, but is there a minor service in between? And does every major service include the same things.
I have my original owners' manual but not the book where the dealer would indicate/stamp that the work had been done.
Could somebody post a copy of this information?
Thanks.
1986 Targa
1968 MGB (2)
Old 03-17-2008, 03:31 PM
