Erik Mckenna's Avatar
it looks like a smoothed out old 935.. which by the way KICKS AZZ!
man you and the guys did some serious f'ing nice work there man..
Goran,
I see the Ring decal.. you guys going back to attack it again and see if you can drop some time off Qvarnis's already fast laps...?
Great machine man.. it really is... i to hope it goes as fast as it looks hahaah! because it looks like it's hauling azz sitting there.
Ciao,
Eric
" The reason the Irish are always fightin each other is that there are no other worthy opponents"
Old 05-06-2006, 05:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #161 (permalink)
MBruns for President
JeremyD's Avatar
I was thinking the same thing - looks like it's hauling ass waiting for a car wash.
Old 05-06-2006, 05:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #162 (permalink)
beepbeep's Avatar
Car landed at 2760lbs dry weight, which is little on the hefty side.
Too many pipes and metal work methinks. Cage is a bit owerworked and plywood sheet under car alone weights 88lbs. It's very very stiff though.
Thank you for your time,
Old 05-10-2006, 12:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #163 (permalink)
Formerly bb80sc
Vipergrün's Avatar
Gnarly! Bet you have not heard that word in a while
How is that rear section attached? Dzus fasteners or something?
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 05-10-2006, 01:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #164 (permalink)
beepbeep's Avatar
It's Dzus but I'm trying to persuade others to rework fastening of rear wing. It looks allright when sitting still and all but wing will produce over 500 lbs of downforce @ 190 mph in it's most optimal position (Torbjörn made Matlab model of this) Those fasteners and wing attachment won't handle that kind of downforce. There is a risk of detachment at speed and in that case car would probably got airborne.
Old 05-10-2006, 03:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #165 (permalink)
beepbeep's Avatar
Car moves! this was some sort of legal streetrace tryout:
A short movie:
http://luminasweden.com/temp/if3divx2.avi
Old 05-22-2006, 09:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #166 (permalink)
Crotchety Old Bastard
RarlyL8's Avatar
That looks a LOT better than the pictures posted earlier.
The video didn't work for me. How'd she run?
Old 05-22-2006, 09:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #167 (permalink)
Limbo
Slider79SC's Avatar
All I get is sound?
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 05-22-2006, 04:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #168 (permalink)
Yup, not working for me either.
Thats pretty damn scary to think that there is a chance the body work can rip off
@190mph . Like you dont have enough to worry about @190.
Goran if there is any chance you can get another interior video on track or at the strip PLEASE post it or any video for that matter
Old 05-22-2006, 04:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #169 (permalink)
beepbeep's Avatar
Good and bad news. Car run on a speed event and run well...speeds of over 200 mph were achieved. Unfortunately something happened with fuel pressure regulator and fuel pressure dropped from 66 psi (which engine is mapped with) to approx. 30 psi. Engine pinged somewhat and was shut down. FPR is now replaced. Engine runs well again but leakdown test is in order.
Pinging can destroy things quickly on turbocharged engines so we hope that leakdown #'s are in the ballpark.
Also, fan belt pulley loosened and belt almost jumped. Generator is moved so we don't have indication of jumped fan anymore. Something must be made to detect unmovable fan.
Old 05-31-2006, 03:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #170 (permalink)
DW SD's Avatar
How about putting a crank position sensor or something similar on the fan pulley or its guts? Some simple logic circuit can light an idiot light if the fan belt breaks?
I hope the leak down works out.
How much HP, have any dyno results?
Congratulations on the progress and speed results - really great! Frontal area is not small with this car, must be a LOT of horsepower.
Doug
1971 RSR - interpretation
Old 05-31-2006, 03:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #171 (permalink)
beepbeep's Avatar
A picture from Speed Event:
Old 06-02-2006, 12:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #172 (permalink)
is it the picture or are you really running that much neg.camber?
WWW.9GEAR.NL
Old 06-02-2006, 01:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #173 (permalink)
beepbeep's Avatar
There is lot's of camber on front wheels.
Old 06-02-2006, 01:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #174 (permalink)
looks like both front wheels are off... was there a bump or just not enough down force on the front to balance it out?
Old 06-02-2006, 03:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #175 (permalink)
rsa rsa is offline
rsa's Avatar
You have to show us more. Stop teasing us!
Scott
77 911s
Old 06-02-2006, 07:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #176 (permalink)
beepbeep's Avatar
We carefully tried the car on real dragstrip during sunday/saturday. We used lowest boost setting (1.2 bar), ordinary street tires and no launch-aids (ALS, launch-control). Only thing we did was to reset rear camber to zero (so those 335:s can have as good footprint as possible) and remove the wing.
First attempt gave us quarter mile time of 10.88s, which is all time best for this car. After more attempts and some minor problems (shredded fan belt, leaky clutch cylinder) we managed 10.40 as best. Traction was superb thanx to many drag cars starting before us.
Trap speed for best run was 141 mph , 60 foot time was 1.72 sec. Best trap speed was 145 mph.
During last run throttle mechansm jammed (those 3.6 throttle wires ) so Jocke had to shut dow the ignition 7400 RPM. Fortunally nothing was damaged. We decided to call it a day and drive home.
I wonder what time car would set when running drag-slicks, 2 bar of boost, ALS and launch-control? It would probably just shear something... Anyway, everyone is pleased with those figures on lowest setting and I personally was glad that engine was completly dry!
Not a single drop of oil underneath.
I'll try to find a video to post later on.
Old 06-11-2006, 10:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #177 (permalink)
beepbeep's Avatar
P.S. Does anyone know what was the fastest time Juan Ruiz posted with his drag 911?
Old 06-12-2006, 08:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #178 (permalink)
When are you guys taking it back to the RING?
Old 06-12-2006, 09:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #179 (permalink)
Juan,s best was 10.76@141mph so you guys did pretty good
87 Carrera Backdate
Old 06-12-2006, 09:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #180 (permalink)
