Ok, Just How Does That Deceleration Valve Work?
I think I finally have my CIS (1973.5T) set up okay with the cold temps upon us, but I do notice sometimes that the idle will drop to the bottom and come back up to its 900-1000 rpm slot. Its only on occasion, but it does raise the question of just how the decel valve works. Its that pretty little bell shaped unit behind the throttle body.
Can it be adjusted? How can it be tested? Is it responsible for my needle dropping? Where does it come into play with the other components? Thanks Bob |
It is responsible for slowing the RPM drop when coming down to idle after shutting off the throttle. It is not "adjustable" but there there are threads that speak to "crushing" is slightly to get it to work properly.
gary |
John F. Lewis 74' 911S Targa + 930/02 76' 914 - Eternal Type IV project FOR SALE |
Have not read the thread, but yes, the earlier ones are adjustable. On the top you'll see a shaft with flats and a locknut. This is the adjustment mechanism. HTH,
ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
My underatanding is that it is an emissions part that helps to burn the remaining fuel after a sudden off the thottle event. Otherwise the car would go very rich for a short time. This is often when you hear cars backfire or the popping of the exhaust.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
There is a small rubber line coming off the Decel Valve. Does anyone know where the other end goes to?
Kurt |
Somatic Negative Optimist
Kurt: There are different Deceleration Valves for different years.
Up to '79, the valve is adjustable as described above. On your '80, the valve is not adjustable. To undestand how the lines connect, do a search on the Pelican diagrams
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
I stand corrected on my "adjustability" answer.
gary |
Gunter, Thanks
Kurt |
Unregistered
The decell valve is a vacuum operated valve that opens under high vacuum and allows air to flow around the closed throttle valve.
At idle, the engine will pull a certain amount of vacuum, prolly around 15 or 16 "HG. Under decelleration, that number jumps, sometimes up to 20"HG or more. Thje valve is designed to be closed at idle but open when the vacuum get higher than normal idle vacuum. When you let off the throttle the vacuum jumps, and a hose sends that vacuum to the valve. The higher than normal vacuum overcomes the spring that holds the valve closed. The valve opens and stays open until the vacuum drops to near idle. If you increase the spring pressure, you make the valve stay closed longer. If you decrease the spring prressure the valve will open at a lower vacuum signal and stay open longer. Basically it is a waste gate that operates by vacuum instead of boost. |
