Congrats - now, how do you clean the engine w/o alerting the other guy in the garage?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Keep us informed...please post pics when you change out your seals.
86' 911 Carerra Last edited by slotcar; 12-21-2005 at 04:19 AM.. |
Not Quite Banned
I love the picture at the end of each session showing the cover back on the car.
You are doing a great job so far. Most of the time there would be a trail of oil and grease footprints all around the car, not to mention discarded beer and soda cans, pizza boxes...no, wait... that is the NoVA engine drop. Keep the pictures coming.
Thomas Owen 1972 911T 1972 911S Last edited by Thomas Owen; 12-20-2005 at 06:11 AM.. |
Keep up the good work-- I mean minor cleaning. We gotta love ya for this project!
Diverdan |
Regards, Guenter 73.5 911T, mod |
this is great fun, as compared to the other posters and my garrage in the middle of a project ! lots o fun watching your project....
"And there's no cure like travel to help you unravel the worries of living today. when the poor brain is cracking there's nothing like packing a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes" |
I'm impressed by what you have done, while being undetected by your neighbor. If he notices the jack, just tell him you had a flat tire.
If my neighbor was as neat and meticulous as you have been, I won't care if you did a complete engine rebuild. This thread is great fun to follow, keep us up to date.
Jeff 1981 911SC Coupe - SSI's + Dansk, MSD, AC delete, Heater Backdate, Euro ride height, polygraphite bushings, Rennshift 1998 F-150 4x4 - Snow Time 1998 Yamaha WR400 - Mountain Ride |
Today I removed the rear fuel lines together with the old CIS fuel pump. I will replace all the rubber lines with new hoses, recycling the metal part of the lines (still wondering if I should use steel braided hose or standard black hose ??). I also removed the two large vent hoses for the evaporation system. One of them was filled with a nasty oil sludge, no wonder the system was not working anymore. Also unbolted the clutch and of course the flywheel needs to be resurfaced. Pretty deep scratches and I hope it can be done within the thickness tolerance. The good point is that the car looks stunning underneath, under all the layers of dirt and deposits. The original PVC undercoating is flawless and shows no sign of cracking or delamination. I guess the constant oil spray from gearbox and engine helped to keep it soft. Always knew there was a reason why these old engines leak some oil.
I like the black hose. It worked for Porsche -- for 30 years or more...
BTW, both Grady & Steve W. reccomend moving the fuel pump up front - there's a thread on it.
Great - first phase of the tear down is completed. Engine tins, front pulley and flywheel are removed. Will now give it a break for the holidays and then I will have to wait for the powder coating and the resurfaced flywheel. Next year we will just have to put everything back together again. As the car will sit for a while, I have stepped up the camouflage. Jacks are almost invisible and even the rear wheels are back on the ground (at least thats how it looks like). Happy holidays to everyone !!
Now in 993 land ...
Nice work. However I think it's time to move. I would not buy or rent something where I am told what to do in the garage. That's going to feel too much like Germany!
![]() George |
Aigel: That is the point bro.
Bernard |
I agree with aigel. I'm not sure worrying about camoflaging your property is worth it. If this were your spouse, it'd be understandable. If possible, I suggest finding a new neighbor or garage (or spouse).
MHO, Sherwood |
The worst thing that can happen is they kick him out for a lease violation. I hear it is really hard to get rid of renters in Calif. so that might take a while. Also, he doesn't appear to be violating the intent of the lease, since he says it reads "minor maintenance" -- i.e. don't make a mess (he isn't).
Nice job! Good camoflauge job, too. You might have better luck using a larger generic car cover temporarily, which would hang down to the ground and cover up any jacks or stands in use (or even let you leave the wheels off the ground.)
Don't worry guys, so far no danger of eviction. And I will move anyway next year, so even the worst case scenario would not be a big problem. While waiting for my powder coater, I went ahead and started cleaning the engine bay. Luckily the 3M adhesive remover works fine for removing the multiple layers of old adhesive from the firewall. After degreasing the whole engine bay will now get a fresh coat of paint. I also had my flywheel resurfaced. Good deal for $30 at a local shop with a diamond wheel. Seems they had never seen a Porsche flywheel before, so I stayed next to the machine to make sure they don't mess it up and grind it all the way to the outer rim. Result looks great and the flywheel is still within tolerance. Should be good for another 300,000 miles.
Damn you work fast Guenter!
So cool... keep it coming...
83 SC (gone) / 72 T (gone) |
I have a newb question for you...what size torx bit are the flywheel bolts? I assume that is what they are...
1987 911 sunroof - just starting out on that slippery slope =-D |
