mschuep's Avatar
Question Starter Ring, which way to re-mount
I am ready to put my engine back in the car after clutch replacement on my 85 Carrera 3.2 . My pressure plate and flywheel are different than before, so I have a couple rookie questions
Which way does the starter ring mount onto the pressure plate? Flat face on transmission side or flywheel side?
Also, right now the starter ring and flywheel notches do not seem to line up perfectly. Would rotating (edit : the ring or pp or both) 120 degrees help line them up?
-Thanks for all the help with first engine drop!
-Matt
-Matt
1985 Targa
Old 12-20-2005, 06:24 AM
inside bevel toward the p/plate.
206 637 4071
Old 12-20-2005, 06:50 AM
mschuep's Avatar
Thanks, I've got it on the right way then.
Unfortunately I still can't get the ring teeth to match the flywheel teeth all the way around. Should I be concerned? It looks like from the wear on the teeth of the starter gear (little guy) that it is only long enough to use one or the other (ring teeth or flywheel teeth).
Any comments? Sorry for the paranoia, but I want to make sure everything is right before re-installation.
-Matt
-Matt
1985 Targa
Old 12-21-2005, 04:41 AM
resident samsquamch
sand_man's Avatar
-Matt
I'm confused. My car is a 930 so maybe there are differences, but there are/is only one set of teeth - the large starter ring gear that is attached to the pressure plate and flywheel assembly. When removed, my flywheel is just a large disc...no other teeth. Then of course there's the small gear on the starter motor that engages the flywheel gear. Have you doubled the large flywheel starter ring gears? Again, my engine is different than yours.
-jeff
Old 12-21-2005, 06:27 AM
mschuep's Avatar
Thanks for trying to help. Both my new and old flywheels have teeth, non-removable ones. There is also a starter ring that mounts to the pp, hence the 2 rows of teeth. Here is a pic of the flywheel.
http://www.pelicanparts.com/cgi-bin/smart/imgdsply.cgi?pn=93010203301-M260
I have seen those without as well.
-Matt
-Matt
1985 Targa
Old 12-21-2005, 06:46 AM
the ring of teeth toward the engine only relate to the flywheel sensors, they don't match up to the starter teeth.
206 637 4071
Old 12-21-2005, 06:52 AM
mschuep's Avatar
Aha ! Fantastic news. Thanks JW I will continue re-assembly.
-Matt
1985 Targa
Old 12-21-2005, 07:00 AM
Friend of Warren
Just make sure you don't do like I did and install the engine and tranny and forget to install the starter ring gear!
Kurt V
Old 12-21-2005, 07:47 AM
Danskman's Avatar
Oh man... that's funny, Kurt. I'm really sorry, but that's funny. I would have punched myself out if I had done that.
Mike
'80 911SC Weissach Edition
'87 325is
'02 K1200RS
Old 12-21-2005, 09:12 AM
