What would be the order of 930 engine mods you would do?
I would like to have reliable 400 RWHP ultimately. Can this be done progressively without wasting time and money? I want to still drive my car during the transition but slowly add/mod things over time if possible.
1) GHL Header & muffler
2) K27 7200 turbo 3) Kokeln intercooler 4) Fuel system upgrade (e.g. Andial Fuel Enrichment) 5) 1.0 bar spring 6) Upgrade K27 7) Replacement boost guage (remove clock)
C.H. Boost Addiction - honestly, I have it under control 1989 911 Turbo Cabriolet Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace Last edited by BlkBird; 12-20-2005 at 08:32 AM.. |
Automotive Monomaniac
What year is the 930? How many miles are on it?
The very first mods would be to make sure your fuel and oil cooling system are up to par before you start tweaking things. You don't want to be running lean, or have high oil temps, from the beginning.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
I'm looking at the same thing. I have a totally stock '87 930. The first thing I'm planning on doing is the suspension. New shocks and bushings all around, lower to 25.5 rear and 25 front (is that too low?). Then align and corner balance the whole mess. Hopefully, I get that all done by spring.
![]() Next winter my plans are to upgrade to K27 and larger intercooler and the 1 bar boost spring. Then an exhaust. There are people here that know a lot more than me about this and I'm sure they'll chime in.....
Bill 997.2 |
The K27 7200 was described to me as a very good turbo but not the best. With it Blkbird had 389 rwHP. Recently the turbo went to Florida for a specialty tweaking - change one of the housings, the blades, etc. Don't ask me for the exact details.
But now Blkbird hits 422 rwHP and is at full boost by 3800 rpm. So whatever magic was performed it worked out well.
C.H. Boost Addiction - honestly, I have it under control 1989 911 Turbo Cabriolet Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace |
Crotchety Old Bastard
The order that I would add mods while using the car:
1) Exhaust System 2) Turbo 3) Intercooler 4) 1.0 Bar 5) Fuel Enrichment if needed (dyno to map A/F ratio to redline) 6) Go into the motor for cams and headwork if you still want more power.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
resident samsquamch
My car has or is getting the following during my total rebuild:
-B&B headers -B&B intercooler -3.4L Ps&Cs -Twin plug heads -Electromotive XDi twin plug ignition system -Tial waste gate with .8 spring -K27-7200 turbo -ARP head studs -ARP rod bolts -SC cams -Modified fuel head -Zork tube "muffler" I have no idea what kind of HP this will give me, I'm just doing alot of it "while I'm in there"...OF COURSE!!!!!!
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP ![]() |
resident samsquamch
I agree 101% with RarlyL8
Yasin
Ole Skool - wouldn't have it any other way |
sell the 930 Engine , add another 5-6 K and get a 965 Turbo 3.6 , take the cat out , 1 bar Spring , and cams and you are at about 400 +very reliable HP . Before you reach real 400 HP with a 79 930 Engine you have at least the same Money spend , the car is barely driveable on the Street and you waste a lot of Time and nervs .
Harald |
Barely driveable? Are you nuts or have you never driven a 400HP 930?
These engines are more mild mannered than a normaly aspirated engine. Mine is downright docile until I kick it. At 400HP you can still use the stock CIS (if you wish).
first off get the valves adjusted and complete a full service/inspection. Start combing the net for deals on used performance parts and be ready to buy,Ebay is great for that. GHL? no thanks.Mid America has B&B systems for $1150.00,way cheaper then GHL and better IMHO(l`ve had both).Get the B&B`s made with a Garrett flange and $700.oo should get you a great Garrett turbo.Juan Ruiz can give you the good specs or l`ll give you mine if you like,basically a stage two Promotive spec unit.A custom full bay intercooler from "goingsuperfast" will cost you about $500.00.Do the CIS mods to keep the fuel ratios in line and make sure you`ve got the MSD or another ignition upgrade$250.00.l`d get a wideband system(PLX 250 with dash guage,$300.00)The stock wastegate is okay if it`s in good condish,if not search for a used 46mm Tial.For the muffler l`d go with the super trick "Aero " stainless topedo typeor a simple flowmaster.Shop it good and for less then $3000.00 you`ll have a monster.The next stage would require you to get rid of the CIS injection but cross that line when you need to,if you ever do.The parts that you`ll be replacing can be sold very easily to finance the mods,don`t worry.l sold my B&B headers and Autothority mass flow system to finance my own turbo conversion and it all worked like l planned it that way.PM me for any details on specific parts,l researched for a couple of years before l did my conversion and l`m pretty familiar with the process.l had a lot of time to plan as l first upgraded my suspension and brakes.good luck
my life begins at 150MPH |
Also, for 500+ it's definately more economical to sell 3.3 all together and go the 3.6 route (preferrably by turbo-converting N/A engine to gain twin plugs, whick 3.6T doesn't have).
Thank you for your time, |
![]() scca_ita: how are you going to use the car? That will affect what engine internals you want/need. Without engine (e.g. cam) mods, I'm not sure if you'd get to 400rwhp... of course, each dyno is different ![]()
87 930 K27HFS/B&B/Twin-Plug... Megasquirted ![]() |
Have you ever driven a 3.6 Turbo 965 or a 993 TT , i guess not or you would know what i am talking about . By Street Driveable i mean a Car would is driving smooth below 2000 RPM and has some power down there too . A car you can go from a dead Stop WITHOUT slipping the Clutch to death . Back in the 80s there was nothing else and we had to live with that , I remeber very good how it was to drive trough the City with a Car bucking like a Horse and flames out the exhaust that the Cop ask me if i want to Burn his Bumper ( i answered that i would like too ,man did i pay for that Joke ) By driving on the Street i am talking about the roads in Town wher you go 30 and have Stops and Traffic lights not inner City Highways ,there it shouldnt be a Problem . Basic Line ,if you do that to a 930 Engine be sure you can keep it over 2500 RPM to enjoy , below it is a Pain . Happy Holidays : Harald |
resident samsquamch
If using the 4 speed, dont forget the close ratio trans/ring & pinion.
Thread Tools | |
Rate This Thread | |
