Where to get Porsche tool P 217?
The factory workshop manual says to use tools P205 and P217 to remove the heat exchanger. Pelican seems to have the eqivaluent of P205 but not P217. Where can I find P217?
Not sure what the P217 is but to remove the heat exchangers on most 911's (?up to 996's?) you need the long Allen for the barrel nuts (P205) and a good flex head 13 mm socket for the other nut on the flange. To reduce chances of snapping off the studs soak w/PB Blaster for a week, tap on the nuts with a cold chisel sevral times and then apply heat from a MAPP torch until the nuts are cherry red (about 2 minutes) then witha nice smooth move loosen them. Still likely to break off a stud or two if these have not been off in years.
Richard Lane 1978 911SC 1973 "Clean" RS clone |
This is what you need, and no other special tools.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
a 13mm dizzy wrench helps...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
I am headed to Sears. Thanks.
I bought the offset wrench from Sears. It does not work.
There are several different offsets..and lengths...I like using a flexible head socket...get a metric set from Craftsman...you will find a LOT of uses for them
Thats my next move. Back to Sears again.
Don,
SIR Tools has a listing ... but it doesn't seem to be for heat exchanger removal! http://www.sirtools.com/porsche_tools.htm
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I saw that.
Virginia Rocks!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
- '72 911T - '81 911SC Euro |
A good alternative for the factory long allen wrench are the T-handle allen wrench sets sold at Harbor Freight - you know the ones with the funky colored handles. They are dirt cheap of course. I have both and I think that the T-handles are easier to use. I recall that I needed to trim a bit of the plastic handle to get the wrench far enough in but that was no big deal.
Steve B 1972 911T
Steve B. 1972 911t 1999 328is |
I found another alternative at Sears, a "stubby" wrench.
