Zedone's Avatar
How to refinish pitted gear shift lever?
I am assuming the shift lever is stainless steel, polished, not chromed. So would I use 400-600 wet dry paper or ultrafine steel wool to remove some dullness and smooth out some pitting?
Just metal creme polish wont touch the pitting , Ive got to get down a layer to smooth that out.
Thanks.
Zed.
Bunch of German cars
Old 12-26-2005, 03:37 PM
randywebb's Avatar
prob. cheap carbon steel...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-26-2005, 04:21 PM
Grady Clay's Avatar
Zed,
Welcome to the Forum.
I’m assuming you are talking about the shift handle between the tunnel and the shift knob. Your ’71 has a chrome plated steel shaft there. You can take a torch to it and bend it to your liking if you want. You can also have it stripped, polished and re-chromed to look like new.
No, it isn’t stainless steel.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 12-26-2005, 04:30 PM
Southern Class & Sass
Dixie's Avatar
I am assuming the shift lever is stainless steel..
The one in my 911 is carbon steel.
Dixie
Bradenton, FL
2013 Camaro ZL1
Zedone's Avatar
Thanks Grady. I was afraid I was gonna have to pull it outta there and take it to the chrome shop.
Old 12-26-2005, 04:53 PM
Grady Clay's Avatar
Zed,
That isn’t all bad. This gives you the excuse to disassemble and rehab the shift assembly. Sorta every 30+ year maintenance, hehe. The lock-out plate for 1-R is probably worn. Possibly the shift housing also. Carefully inspect the pin in the housing and the slot in the shift handle. Check the connection at the front of the shift rod in the tunnel. Replace the plastic shift cup, the plastic bushing in the tunnel and the two plastic pieces at the coupler to the transmission shift shaft.
Good old 911s deserve some TLC.
Best,
Grady
Old 12-26-2005, 05:22 PM
Zedone's Avatar
Grady,
Yes, it was a bit sloppy the little I drove it before the snow arrived but not bad. Would this be the time to consider a Rennsport shifter for this 901 rather than redoing the existing? It comes with a new shift lever
Old 12-26-2005, 05:56 PM
