She/Her
BeauBlues's Avatar
When installing headlight relays...
Im a little confused on what wires I should take from the fuse box and connect to the relays. Any thoughts.
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 12-27-2005, 12:17 PM
Somatic Negative Optimist
Gunter's Avatar
Do a search for this; lot's of info here on wiring.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-27-2005, 12:35 PM
Here's a diagram I made for a 1980 911SC that may help.
John Adams
1980 ROW 911SC
Old 12-27-2005, 01:00 PM
}{arlequin's Avatar
Re: When installing headlight relays...
your fuse box should be labelled w/ R and L high and low. can't tell you off the top which pin on the relays is the "on/off switch" for the relay, but that's the pin that each headlight's wire from your fusebox should be connected to. (a search will reveal which pin does what on the relays. plenty of diagrams here ab. this)
i used 4 relays so it will be a little different if you're using 2. if 2, then i'm not sure if it's better to have one relay control both lows and another both highs, or entire left side vs. right side...
i'd prefer left/right b/c if one died then i'd still have light as opposed to having to continue driving on highs.
dave
1973,5
Old 12-27-2005, 01:30 PM
She/Her
BeauBlues's Avatar
Ok thanks for the help on the fuses. I now know which wires to use.
Ok just one more thing, say if I wanted to rewire the grounds for the bulbs, where is an optimal ground location? In the headlight bucket? Or somewhere else?
Gwyneth *she/her
1995 993 Guards Red
Old 12-27-2005, 04:19 PM
Large Registered Member
PatrickB's Avatar
where would one purchase this Sucro Relay kit?
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 12-27-2005, 04:27 PM
austria3's Avatar
try this
Stefan
'78 911 SC crashed & gone, but not forgotten
'77 911 S
www.carmania.at
Old 12-28-2005, 10:14 AM
