BRB-83-911SC's Avatar
Weltmeister Short Shift
Hi Folks - I have the Weltmeister short shift kit (spacer plate and modfied shift lever). I would like to convert back to stock set-up. Am I correct in assuming that all I need to do is locate a factory shift lever and remove the spacer plate, and use shorter housing bolts? If so, I will be looking for a non-short shift lever. Anything else to consider? Thanks.
Brian
84 928S Euro
Old 12-28-2005, 05:16 AM
Vin-barrett's Avatar
I just did this
You only need one shorter housing bolt, the one farthest rear (13mm head)
The rest can stay
-Vinny
1983 911SC
Old 12-28-2005, 01:46 PM
