JTL JTL is offline
JTL's Avatar
Smile 3.2 engine-trans separation
Now that both the engine and trans are free from the car they need to be separated. Is there anything special to keep in mind? Three bolts/nuts are visible from the trans side as far as I can tell... The motor is going on a stand tomorrow.
jt
-84 targa
Old 12-29-2005, 06:30 PM
What projects are you undertaking?
86' 911 Carerra
Old 12-29-2005, 06:35 PM
From the look of the engine, I can see the Omega spring is still attached. The engine will not separate. Do this.
1. Lay on your back, and reach for the clutch helper arm (the small one)
2. Remove the circlip and slide it off.
3. Slide off the big clutch actuator arm (the thing where your clutch cable is attached to)
Now, remove the starter, and then the 3 15mm nuts holding the engine and tranny together.
Slide the tranny off.
Sounds easy?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-29-2005, 06:43 PM
JTL JTL is offline
JTL's Avatar
1. Serious cleanup of engine and trans.
2. Fix small oil leaks; crank pulley seal and oil return tube(s),
3. Inspect clutch and flywheel.
4. Install new shocks.
5. Repack cv's.
Those old heat exchangers and muffler sure look ugly; don't know if I can bring myself to reinstall those once they are off. The problem with changing to headers or ssi's is how to get the car to pass emissions.
jt
Old 12-29-2005, 06:52 PM
Sounds good...please post pics as you progress.
86' 911 Carerra
Old 12-29-2005, 07:00 PM
JTL JTL is offline
JTL's Avatar
Thanks Yelcab! That's a piece of cake. The combo is still on a trans dolly and a jack, which can both be adjusted up to access the bottom. And no, I won't go under it without proper support How do I know what position to reinstall the actuator arm though??
Old 12-29-2005, 07:02 PM
You can mark it, but it is pretty intuitive though.
Old 12-29-2005, 07:29 PM
911Atlanta's Avatar
Consider also swapping those pesky (and prone to failure) little $10 switches, sensors and the like on the back end of the engine that are very difficult or impossible to reach when it's installed.
Dan
'87 911 Carrera - Cabriolet
Old 12-29-2005, 07:34 PM
JTL JTL is offline
JTL's Avatar
You are no doubt referring to the infamous oil pressure switch. I'll be sure to change it. I can't wait to clean it up a bit in order to see what's back there
BTW, I lived in Atlanta for 5 years; Toco Hills and Suwanee... The wife talked me into moving to the midwest; it's ok but I'd much rather be either East or West coast.
jt
Old 12-29-2005, 07:49 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
In addition to the pressure switch, definitely replace the TDC and Speed sensors on the flywheel. You also might wanna replace the Head Temp Sensor. It's much easier to reach right now.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 12-30-2005, 12:25 AM
rob justice's Avatar
If you don't want to replace the TDC and Speed Sensors, I would at least check that they're not seized into their housing, they usually do in damp climates - remove each one and give it a good clean.
The hex hed screws that hold the sensors in place also like to seize up - I replaced with stainless fasteners and plenty anti-seize.
If one goes faulty and its seized - your not far from another engine drop because of lack of access.
Also you won't get a better chance to check the valves.
Also keep on posting photos!!!
Old 12-30-2005, 02:12 AM
