928S4 front & 951 rear brake upgrade for 78 911?
I have tried to do searches but it only mentions Bigred and other types of brake upgrades..
is there a list anyone has of all the items needed to complete a full swap onto a 78 911 ?? -TIA. Eric
" The reason the Irish are always fightin each other is that there are no other worthy opponents" |
Irrationally exuberant
I did the S4(993) front brakes on my '86. It was very expensive - more than Big Reds. The 930 floating front rotors are ~$390 each.
Check out Bill V's web site if you haven't already: http://www.pelicanparts.com/MotorCity/wmv/brakes.htm -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
The 928S4 and 951 rear calipers are virtually the same and both have 30/28 pistons.
John
1985.5 944 GTS |
hard to believe that search didn't turn up a large # of threads
but once more you need 1 x complete set of 993 calipers front and rear. 2 x caliper adapters for the front 2 x modification to 3" axial mount at the rear & modified throat. 965 rear can also be used and are more desireable due to the wide throats that are oem. 2 x front pads set 2 x rear pad set 4 x axial mounting bolts front 4 x radial mounting bolts front 4 x axial mounting bolts rear 4 x flex lines & fittings 2 x 304x32mm front rotors and mounting hats(DIN has 309x32 that also work) 2 x 309x28 mm late 930 rear rotors 2 x remove rear dust shield & mounts you do not want any of the 28/30 variants 964/951/944/928
Thanks guys!!!!!
Bill, I tried but I wanted to make sure the info I was getting was for the S4 set and not the BIG Red set.. Thanks for the info. Chris. yeah I am not going to go with floating rotors ( if I can help it ) as they DO cost a bundle... -Eric
$350 ish - set 993 calipers and pads from a WTB post on rennlist 993 forum $415 ish - front adapters, hats and rotors from probrake $180 ish - 930 M/C $320 ish - 930 rear rotors TBD - new hard brake lines these prices are off the top of my head, but ballpark. So roughly $1300 minus whatever you can get for your old brake setup. -Bernie
Database and Website Consulting Services in Chicago |
Quick question guys about the extrenal lok of the 993/S4 calipers.. I have seen a set for sale VERY cheap and the one this is they are the same caliper and all but the kettering on one is raised ( like a 951 caliper ) and the other it's a painted decal... do you think they are diff or is it just that they changed the PORSCHE font the on the outside of the caliper.. i am hoping that they are the same pistion size and all..
Id there anything I can get off the caliper that would confirm that they would work with one another given the fact that they have diff PORSCHE font? let me know if you would need a part number or anything I'll get it for you . I just don't want to buy them and find they won't work with one another.. but again they are the same looking caliper and all from what I can tell. TIA Eric
Who is "probrake"? Do you have a link? -Chris
Http://www.ProBraking.com
here's a thread of them being put to use... Busy weekend coming up - Brakes and such i dont think this is sold on pelican, but mods feel free to edit this if I'm biting the hand that feeds this board. -Bernie
Besides that they are obviously not a matched set, I wouldn't touch them.
ok.. ok.. I ditched the caliprs I had.. i bought a set of 993C4 silver calipers from ebay sop NOW I have the good stuff up front.
I think there is SO MUCH info on this now I have (OVERLOADED myself).. I have 993 front calipers... and 951 rear calipers.( IS THERE A PART # FROM SOME THAT I CAN CONFIRM THIS WITH). is this NOT a good idea? should I sell the 951's and get some 993 rears ? or is there a way to make this work with what I have and can I use a standard 930 rear rotor with the 951's IF i keep them.. ?? sorry but I am so lost in all the info. I have read that I can make the 993's front work with 930 rotors.. and now I am confussed on the rear set up... ARGH!
" The reason the Irish are always fightin each other is that there are no other worthy opponents" Last edited by Erik Mckenna; 12-28-2005 at 06:05 PM.. |
bump for new day
you want 993 or 965 rear calipers both have 30/34 pistons, the pad box on the 965 is 98mm x 67.5mm, the pad box on the 993 is 98mm x 63.5mm but can be widened enough w/ a grinder the 34mm pistons can be identified by measuring the external portions of the piston head O/I diameter 26.5mm x 15mm the 30mm pistons can be identified in the same way, diameter 26.5mm x 12.5mm the 28s are 24x12mm
