schoward's Avatar
1981 911SC Alarm Control Unit Part #
Anyone know what the correct part # is for the factory anti-theft control unit module (that is in luggage compartment I believe)?
Car is US-spec 1981 911SC with door jamb alarm key switch.
Pelican lists several with 911-637-104.xx part #s
Not sure if any of those are correct for 911SC and would check myself but car is away in storage for the winter
Thanks in advance!
Old 01-02-2006, 08:23 AM
PET shows 911 637 104 00 for your car.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 01-02-2006, 08:27 AM
schoward's Avatar
Man, this is like real time! Many Thanks!
Old 01-02-2006, 08:32 AM
Early_S_Man's Avatar
Porsche Crest
schoward,
Here is a thread you may want to read and print out for future reference:
'82 SC Won't run
If your factory alarm is inoperative or acting up ... there is a 'bypass procedure' you should know about and be prepared to do. Otherwise, your car may be inoperative when/if the factory alarm unit fails!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-02-2006, 10:30 AM
schoward's Avatar
Early s man - just what i needed. thanks.
I will attempt to resurrect the alarm this spring and am assuming the worst (which is that I will likely disturb some old patchwork fix/disablement) and need all the info i can get
Old 01-02-2006, 12:36 PM
