Spark Plugs after turbocharging....?
Speaking of spark plugs, what are you guys using after slapping a BAE, Protomotive or home brew setup onto your 911? I don't recall seeing recommendations mentioned. Surely if the compression is being effectively raised one must go to a colder plug.
Warren & Ron, may you rest in Peace.
Old 01-03-2006, 08:14 AM
Unregistered
sammyg2's Avatar
No change here, but IMO I'm not running enough boost to make a change necessary.
My plugs look OK after inspection, no signs of running too hot that I can see. If I were running under full boost all the time if might be different but my engine only sees boost for short periods of time.
Old 01-03-2006, 08:20 AM
Interesting. Do you know of a fomula to convert boost pressure into the effective compression ratio?
Old 01-03-2006, 10:36 AM
Unregistered
sammyg2's Avatar
Here's some good ones, but you need to know the VE of the engine.
http://www.turbofast.com.au/javacalc.html
Old 01-03-2006, 10:46 AM
