unclenick's Avatar
Send a message via AIM to unclenick
Question fuel line question-need part number
On my 78 911SC there is a fuel line which starts right outside the "tunnel" for the shift rod and runs up along the left side of engine compartment, then goes directly to the engine via a 3 part tee(see photos attached) this line was all crusty and brittle so I cut it anyways. Now I need the part number for this line. I am installing all new hoses before I put the engine back in the car and need to order this line. I cannot find it listed on the web site in Fuel parts. Thanks
It starts here coming out of the "tunnel"
then goes up along the left side of engine compartment(the middle line)........
and then connects here on engine.................on back left of engine............
Is this the return line?
1984 RoW Carrera Cab
1986 944 Turbo-sold for new home
2005 Suzuki Hayabusa-sold for new home
1986 928s 32V-sold
1978 911 Targa-sold
1987 924S-sold
Old 01-04-2006, 04:46 PM
HarryD's Avatar
One alternative is to disconnect the hose (you will have to do it anyway) and bring all of the parts to a hydraulic shop. Have them use your ends and swedge on new rubber. The cost will be a fraction of Por$che and you will have it done in about 20 minutes.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-04-2006, 05:23 PM
unclenick's Avatar
That is what I was thinking but since I have a grocery list ready to order here, I figured I get it with the rest of the parts.
1986 928s 32V-sold
1978 911 Targa-sold
1987 924S-sold
Old 01-04-2006, 05:32 PM
BoxsterGT's Avatar
This looks like a simple straight hose w/ a female at one end & a male at the other.
What length do you need?
I make a "fuel hose fix" for the 944s that replaces the $300 hose that goes to the fuel rail inlet.
I am just starting to make a replacement for the $500 fuel supply hose for the 84-89 911C 3.2 that goes under the intake.
I can duplicate or repair or custom make most Porsche hose assemblies, including the big oil hoses.
Any questions you can email me at len@autosportengineering.com
I would be happy to help.
Len
Old 01-05-2006, 03:32 AM
Blanco's Avatar
I just did an engine drop and had to cut this same freaking hose!!!
I'm having a hard time removing the fittings.... can I just splice them together?
Alex
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 02-26-2006, 07:17 AM
BoxsterGT's Avatar
If the hose is on the low pressure return side you can splice it together without worry.
If it is a hose on the high pressure supply side, you cannot use clamps safely. It must be crimped.
If the hose is under high (3 bars typical) pressure, and it has a straight fittting at one end, give me the overall dimensions & I can make up a new hose.
The small 16mm fuel fittings are between $8 and $12 ea, and the hose is about $20 per meter for the plain rubber and a bit more for the braided Stainless (metric, not AN) hose.
If it has angled fittings on each end, I must send the loose hose & fittings to you for fitment and marking of the orientation of the angled fittings. You must send them back to me for crimping.
Same procedure for the big 30mm oil hose assemblies.
I hope this helps.
Len
Old 02-26-2006, 05:09 PM
