Eye of the Toiger
What type of structs does a 74 911 have?
I want to put some bilstiens in the front of my 74 911 currenty I have an old set of Koni's but I'm not sure what struts the 74 model had, can anyone shed some light?
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
drag racing the short bus
If you're talking about shocks, I think any Bilstein shock (HD or Sport), will fit.
The Terror of Tiny Town |
'74's had either Boge, Koni or Bilsteins.
The latter 2 were the sport shock options used in those years.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Either way at this point you should change them!!
Koni has a wide variety of adjustable shocks if your keeping the tbars. If you are going coilover then the sky is the limit but I have found that dartauto.com has some great prices on bilstein rsr struts. Other options would be jrz, penske, moton, bla bla bla, anyone will make anthing as long as you pay for it. If its a street/track car the dartauto rsr's are not that far off from new custom valved inserts and new tbars. Its all up to you and your wallet. best of luck, ryder
74 911s neverending story. two feet and a jetta for now. |
Go to the Pelican Tech Articles section. There is an article titled " 911 Suspension Spotting Guide". It shows several types of struts and should help you spot the type of strut you have. If all else fails, you can get the part number from your strut (not shock) and cross reference here or with your shock supplier. As I understand it, if you have Koni struts you can only use Koni shocks (unless you change the entire strut), but if you have Boge struts you can switch from Koni to Bilstein shocks.
Tony G 2000 Boxster S |
