cnielsen's Avatar
tranny diagnosing question...LSD or not
I recently purchased an SC to use as a daily driver and apparently it was ordered with a Limited slip diff. I have one in my other car and I know the wheels are supposed to spin the same direction with the LSD and the opposite direction with an open diff.
Well on this SC, if you spin one tire manually, the other one does not move at all. Both can be moved independantly but it does not affect the other side.
What tranny do I have or is there a problem with the internals of the tranny...everything seems to drive fine though
Any help would be much appreciated.
Chris
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 01-06-2006, 07:03 AM
pwd72s's Avatar
Either a malfunctioning limited slip or no limited slip...
Old 01-06-2006, 08:24 AM
Somatic Negative Optimist
Gunter's Avatar
Chris:
My LSD works as described: Turn one wheel and the other one turns in the same direction.
Hope someone knows the answer to your riddle.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-06-2006, 11:04 AM
Is the car in gear or neutral?
Old 01-06-2006, 11:45 AM
Bill Verburg's Avatar
the disks do wear, causing the break away force to asymptotically approach zero
the dynamic breakaway force will always be greater as the applied torque increases
Bill Verburg
Old 01-06-2006, 01:50 PM
cnielsen's Avatar
so could it be worn discs? Is this part of a general rebuild or does it involve replacement of the LSD? What is the damage on something like that?
Yes, the car was in nuetral.
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 01-06-2006, 05:08 PM
Yes, they lsd did can be rebuilt w/ new friction discs, IIRC ~$700
Bill Verburg
Old 01-06-2006, 05:15 PM
beepbeep's Avatar
Even worn discs will turn other tire in same direction if both are off the ground and brake ain't binding.
If other tire doesn't move at all, you have plain vanilla open diff.
Thank you for your time,
Old 01-06-2006, 07:25 PM
Look at the bottom series of numbers on the transaxle casing... look for the "-12" between the type# and serial#. If it's there, it should have LSD.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-06-2006, 07:32 PM
That most certainly is not true. I have a lsd equipped G50 in my gararge right now. Worn discs and no rotation of the opposite wheel.
Discussions w/ several well respected transmission/diff guys confirm it.
Bill Verburg
Old 01-07-2006, 05:15 AM
cnielsen's Avatar
OK, so I looked at the original bill of sale from the factory and the car was supposedly delivered with a LSD tranny. If I have a worn disc, is there any problem with driving it as is? The rest of the tranny works well...little hesitation in some gears and careful downshifts. I guess the question is: am I going to do more harm by not fixing it now?
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 01-08-2006, 01:28 PM
Chris:
Your LSD is simply worn out,.... If you didn't have an LSD, the opposite wheel would turn the other way when you rotate a wheel.
Its pretty simple to pull it out the side cover, unbolt the ring gear and have it rebuilt (after you drain the oil, of course).
You'll not do any harm by leaving it alone.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-08-2006, 02:13 PM
PorscheGuy79's Avatar
I would confirm model numbers, the car may have been delievered with an LSD but who knows what happeneds over time with different owners. I would be sure that it truely is an LSD before you go to the hassel of tearing it apart.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 01-08-2006, 02:24 PM
PorscheGuy79 makes a good point.... verify that it *should* have LSD first ...( first-things-first, huh?)...
Look for the -12 as stated earlier...
- wil
Wil Ferch
Old 01-08-2006, 06:34 PM
