chrisp's Avatar
Need help indentifying a Bosch distributor
Can you tell from this pic if it's in good shape? I am buying long distance sight unseen so any help you can give me would be appreciated.
Also, the part number stamped on it is 0 237 304 015
It's claimed to be an SC dizzy but I don't think the part number jives. However, I don't know all of the part numbers out there especially when you consider rebuilds, etc.
Thanks.
'83 SC
Old 01-08-2006, 06:46 PM
Early_S_Man's Avatar
chrisp,
If you happened to misread [or mistype] the last digit ... that would be the correct Bosch pn 0.237.304.016 for a 1980 - 83 SC!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-15-2006, 12:38 PM
It is definitely an SC distributor
As for condition, check the play in the dist shaft for worn bearings.
Hard to do long distance, I know!
Can't tell from the pic whether it's single or dual vac take-off
single vac is 78-79, dual is 80-83
Old 01-16-2006, 02:37 PM
chrisp's Avatar
Thanks guys. The part number wasn't a typo and that's the issue. I can't find any records showing a dizzy with that part number.
'83 SC
Old 01-16-2006, 06:36 PM
Wait a second, this thing is not long enough to be a 911 distributor.
and where is the tab with the adjustment slot?
The big aluminum stop that is part of the distributor body.
Could this be a dizzy from an early 80's 6 cyl BMW?
Looking at the dizzy pic for an SC in my Factory w/s manual,
this thing is all wrong!
Sorry for the erroneous info in my last post!
Old 01-16-2006, 07:32 PM
