Mocked up on the rear
http://forums.pelicanparts.com/uploa...1738542522.jpg The compression/rebound adjuster is going to conflict with the hood so Wyatt at MCS sent some bushings in. Will install soon. http://forums.pelicanparts.com/uploa...1738542522.jpg |
Quick fit check with the new tires/suspension - needs fine tuning but the look is mean! http://forums.pelicanparts.com/uploa...1738542767.jpg
http://forums.pelicanparts.com/uploa...1738542989.jpg |
Happy to see this thread resurrected! I followed this build back in the day. You'll love the MCS shocks. They're great!
I recently read through this entire build thread, what an amazing car and spec!! Sadly it sounds like the saga with Mr. Timmins left a sour taste in Matteo's mouth, rightly so after spending this much money.
You made a hell of a buy Robert, for sure much less than Matteo paid back in the day, and half of what it would cost now to build, even if you don't count the years spent waiting and organising. Very cool that you are updating the car to top of the line modern EFI, and also adapting it to you needs. I like it even more as a long hood now, and the RSR bumper will fit the overall aesthetic and performance for sure. Please keep posting pics and updates, there are many of us who enjoy following along (even if many never post).. Cheers from Austria, Lukas |
New front bumper mocked up. It’s in for final paint and I’ll have this week.http://forums.pelicanparts.com/uploa...1739064969.jpg
Not sure if I should install before the re-wire and paint correction is done or afterwards? |
Ran new stainless steel brake lines front and rear and flushed all the break fluids, replacing with Motul 660… Working on odds and ends while I work through final electrical plans… Electrical has become a major nightmare and will post separately on some questions/soul seeking…
http://forums.pelicanparts.com/uploa...1739406441.jpg http://forums.pelicanparts.com/uploa...1739406728.jpg |
Front bumper is back from paint and looking nice!:D
http://forums.pelicanparts.com/uploa...1739927791.jpg I’m going to sell the old one if anyone is interested (will post in classifieds) |
Didn't the RSR have a whale tail not a duck??
Im still removing dynamat remains from this thing….. getting closer but does anyone have any secret sauce? I’ve been using mineral oil and citrus remover… Doesn’t need to be perfect when I’m done as it’s getting carpet but really prefer a clean slate.
http://forums.pelicanparts.com/uploa...1740355026.jpg http://forums.pelicanparts.com/uploa...1740355026.jpg |
are you removing it to save some weight, or do you feel it just isnt effective in sound mitigation? Car is looking great by the way.
To save weight... But after the 20+ hours of dealing with this it wasn't worth it. I think we saved about 20 - 25 lbs (some areas were double coated). Worst idea I've had. Ha.
The electrical / re-wire is turning into a nightmare…. While
I figured that out I’ve ordered a Numeric racing shifter and rod. Also took the pedal assembly out for cleaning and to replace any worn bushing etc. http://forums.pelicanparts.com/uploa...1741025078.jpg http://forums.pelicanparts.com/uploa...1741025078.jpg http://forums.pelicanparts.com/uploa...1741025078.jpg |
Installed the Numeric racing shifter and rod. I bought the wood look shifter knob to keep it a bit retro. Also, mocked the new front bumper up and it’s looking great. I got new LED lights and think I am going to install the old H4 lenses in the new LED light body.
http://forums.pelicanparts.com/uploa...1742663390.jpg http://forums.pelicanparts.com/uploa...1742663390.jpg http://forums.pelicanparts.com/uploa...1742663390.jpg |
Also, the Recaro pole position seats are getting stripped and cleaned up. They will get repainted gloss black (the original Mexico Blue color is just a bit too much for me!), leather conditioned and dyed and inserts are being reupholstered basket weave black leather like the below…
http://forums.pelicanparts.com/uploa...1742668172.png |
Finally got the inside of this car clean! Will do a final scrub and repaint some minor spots where paint chipped or was severely scratched before we do the interior… http://forums.pelicanparts.com/uploa...1743523369.jpg
http://forums.pelicanparts.com/uploa...1743523369.jpg I want to replace the engine fan shroud and tin. Assuming I need to drop the engine to do so? Looks like Damon and Series 900 has received a lot of recommendations for the fiberglass setup - any thoughts or other recs? |
It sure would sure be easier to change the tin with it out, but a partial drop would also allow it to be done, albeit with more effort and curse words.
The car is pretty well cleaned up and ready to be wired… I settled on Technica Racewire to supply the harnesses, COP, Motec and PDM. I’ll install it from there and we’ll get it shipped off for professional tuning. Scope below - any thoughts?
Ignition Setup Twin Plug (12x) Denso 4 Way Coil Injectors Injectors (6x) Injector Dynamics ID-1050X Cam Clewett Cam Sensor Crank 964/993 Crankshaft Position Sensor Slytech TMAP Sensor IAT Fuel Pressure Slytech Combo Sensor Engine Temp Factory Porsche 911 Engine Temp Sensor Knock Sensor (x2) Oxygen Sensor (x2) Oil Pressure Oil Temp IACV 3 Bosch IACV Factory Porsche 993 Bosch LSU 4.9 Slytech Combo Sensor |
I’m not in love with this cable throttle assembly as it (a) a little messy looking and (b) will require constant adjustment as the cables stretch and (c) I’m worried about reliability. Since I’m changing out the shrouds I’d like to get this cleaned up now too. Any recommendations on system?http://forums.pelicanparts.com/uploa...1744133140.jpg
http://forums.pelicanparts.com/uploa...1744133140.jpg http://forums.pelicanparts.com/uploa...1744133140.jpg |
The new wire harness, motec, COP etc is getting put together and tested still… I’m cleaning up some odds ends and purchased sheridan fiberglass shroud and tins to install. Also dropped in some titanium intake studs well I’m at it for longevity / looks. Cleaning and replacing other odd bolts etc as well.
http://forums.pelicanparts.com/uploa...1745715684.jpg http://forums.pelicanparts.com/uploa...1745715684.jpg |
Hopefully down to the short stuff here…. Cars loaded and being shipped off for install of the new electrical/motec setup and will roll into tuning of the engine and suspension. Hopefully get everything done this summer (off-season in AZ) so I can get in on the road and track this fall. Will continue to do some misc small projects while this is getting done.http://forums.pelicanparts.com/uploa...1747002570.jpg
http://forums.pelicanparts.com/uploa...1747002570.jpg |
I followed this build back in the day, and it's nice to see that you're continuing with developing it further and making it your own.
Rebuilding the pedal cluster - I’m going to have these parts all powder coated before it’s put back together for longer term rust / brake fluid protection.http://forums.pelicanparts.com/uploa...1747341357.jpg
Updated exhuast is fully mocked up and ready for final adjustments/clean up once the engine is dropped. Just need to remove/adjust the old brackets for final fit. These are going to be LOUD! http://forums.pelicanparts.com/uploa...1748963291.jpg
http://forums.pelicanparts.com/uploa...1748963291.jpg |
Installing now! These Technica Racewire harnesses look amazing.
http://forums.pelicanparts.com/uploa...1752007636.jpg http://forums.pelicanparts.com/uploa...1752007636.jpg http://forums.pelicanparts.com/uploa...1752007636.jpg |
After a long summer break we’re finally getting ready for start up. Transmission cooler is in, new tins, Motec and wiring being wrapped up and putting it back together. Start up is scheduled for this week with the tuner and will post some videos. We’ll get things all put together after startup and then dyno & tune a couple of weeks afterwards.
http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg |
| All times are GMT -8. The time now is 12:36 PM. |
