The car is pretty well cleaned up and ready to be wired… I settled on Technica Racewire to supply the harnesses, COP, Motec and PDM. I’ll install it from there and we’ll get it shipped off for professional tuning. Scope below - any thoughts?
Ignition Setup Twin Plug (12x) Denso 4 Way Coil
Injectors Injectors (6x) Injector Dynamics ID-1050X
Cam Clewett Cam Sensor
Crank 964/993 Crankshaft Position Sensor
Slytech TMAP Sensor
IAT
Fuel Pressure Slytech Combo Sensor
Engine Temp Factory Porsche 911 Engine Temp
Sensor
Knock Sensor (x2) Oxygen Sensor (x2) Oil Pressure
Oil Temp
IACV 3 Bosch IACV
Factory Porsche 993
Bosch LSU 4.9
Robert Guerena
992 GT3
1970 ST 3.2 Hot Rod
1974 RSR 3.8 Backdated
Old 04-08-2025, 10:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1501 (permalink)
I’m not in love with this cable throttle assembly as it (a) a little messy looking and (b) will require constant adjustment as the cables stretch and (c) I’m worried about reliability. Since I’m changing out the shrouds I’d like to get this cleaned up now too. Any recommendations on system?
Robert Guerena
992 GT3
1970 ST 3.2 Hot Rod
Old 04-08-2025, 10:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1502 (permalink)
The new wire harness, motec, COP etc is getting put together and tested still… I’m cleaning up some odds ends and purchased sheridan fiberglass shroud and tins to install. Also dropped in some titanium intake studs well I’m at it for longevity / looks. Cleaning and replacing other odd bolts etc as well.
Robert Guerena
992 GT3
1970 ST 3.2 Hot Rod
Old 04-26-2025, 06:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1503 (permalink)
Hopefully down to the short stuff here…. Cars loaded and being shipped off for install of the new electrical/motec setup and will roll into tuning of the engine and suspension. Hopefully get everything done this summer (off-season in AZ) so I can get in on the road and track this fall. Will continue to do some misc small projects while this is getting done.
Robert Guerena
992 GT3
1970 ST 3.2 Hot Rod
Old 05-11-2025, 03:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1504 (permalink)
Garen's Avatar
I followed this build back in the day, and it's nice to see that you're continuing with developing it further and making it your own.
Garen
GNdesignLLC.com - Automotive Art & Sculpture
Old 05-13-2025, 06:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1505 (permalink)
Rebuilding the pedal cluster - I’m going to have these parts all powder coated before it’s put back together for longer term rust / brake fluid protection.
Robert Guerena
992 GT3
1970 ST 3.2 Hot Rod
Old 05-15-2025, 01:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1506 (permalink)
Seats are done with upholstery… 😍
Robert Guerena
992 GT3
1970 ST 3.2 Hot Rod
Old 05-21-2025, 06:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1507 (permalink)
Updated exhuast is fully mocked up and ready for final adjustments/clean up once the engine is dropped. Just need to remove/adjust the old brackets for final fit. These are going to be LOUD!
Robert Guerena
992 GT3
1970 ST 3.2 Hot Rod
Old 06-03-2025, 08:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1508 (permalink)
Installing now! These Technica Racewire harnesses look amazing.
Robert Guerena
992 GT3
1970 ST 3.2 Hot Rod
Old 07-08-2025, 01:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1509 (permalink)
After a long summer break we’re finally getting ready for start up. Transmission cooler is in, new tins, Motec and wiring being wrapped up and putting it back together. Start up is scheduled for this week with the tuner and will post some videos. We’ll get things all put together after startup and then dyno & tune a couple of weeks afterwards.
Robert Guerena
992 GT3
1970 ST 3.2 Hot Rod
Old 10-05-2025, 12:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1510 (permalink)
