gumba's Avatar
930 exhaust system upgrade '79 to "86
I'm looking into upgrading the exhaust on the '79 930 to an '86. What other parts do I need other than the 2 heat exchangers and cross over pipe. Someone implied there is a pricey little pipe I also need to relocate the waste gate. I'm going to retain the DP muffler.
Thanks,
H.
'79 930/DP935
Old 01-14-2006, 09:25 AM
Forced Induction Junkie
WERK I's Avatar
gumba,
It's called a "j-pipe" and it connects the passenger side header to the driver's side header. They are somewhat pricey, but I think someone is manufacturing SS types that will last longer than the OEM.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 01-14-2006, 11:11 AM
gumba's Avatar
The guy at the wrecking yard called a exhaust gas line. Ties the turbo to the wastegate. List is $1500, used around $400. Does that sound right?
thanks,
H.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 01-14-2006, 11:44 AM
WERK I's Avatar
Are you referring to this pipe? It is available from Pelican, but you're right it is very expensive(over $1K)
Dave
Old 01-14-2006, 01:17 PM
gumba's Avatar
That's the one. PET refers to it as "exhaust gal line".
Harold
Old 01-14-2006, 01:47 PM
gumba's Avatar
sorry, "exhaust gas line"
Harold
Old 01-14-2006, 01:51 PM
WERK I's Avatar
$400 isn't bad price. Check the flange areas for cracking and the pipe for splits and dents. Other than that, you'd be good to go!
btw, you might want to check the 911/930 boards(Rennlist and Pelican). Maybe someone has one laying around.
Dave
Old 01-14-2006, 02:05 PM
cycling has-been
bkreigsr's Avatar
not to hyjack, but Dave can you offer an opinion on my similiar situation?
thanks
Bill K
77 930 euro exhaust vs us
Old 01-14-2006, 02:18 PM
WERK I's Avatar
I'll check the PET or Bruce Anderson's book when I get home from work. There are excellent pics in Bruce's book that give a visual side-by-side comparison of the early U.S. version and the RoW, and 87-89 U.S. 930's. The early U.S. exchangers/pipes are quite restrictive. Smaller diameter pipes and the tri-y type flange feeding that small pipe is not condusive to feeding a hungry turbocharger.
There have been estimates of 20-30 BHP gains when cutting over to this style of exhaust from the early U.S. version.
Dave
Old 01-14-2006, 02:35 PM
gumba's Avatar
Is a Euro exhaust system the same as the '86-'89 US?
H.
Harold
Old 01-14-2006, 03:25 PM
WERK I's Avatar
Yes.
Dave
Old 01-14-2006, 03:50 PM
Crotchety Old Bastard
RarlyL8's Avatar
You can buy an entire '78-on Euro 930 exhaust system used for $400-$500. I would not bother with that pipe for that money, that's a rediculous price.
Old 01-14-2006, 08:40 PM
check EBAY item # 8030351456
Old 01-15-2006, 04:09 AM
