zmayne's Avatar
Smile Removing/working on '69 911T gauges
Anybody here know a quick and easy way to remove the gauges on a 1969 T? Some of the wiring is loose and making one gauge flicker, plus others need some new bulbs.
Also, any tips on making the gauges brighter with different bulbs, etc?
Any help much appreciated!
1969 Porsche 911T, 1988 Porsche 924S, 1985 BMW 635CSi Euro, 1995 BMW E36 M3
www.retromodcars.com
Old 01-13-2006, 06:15 PM
There's no real quick and easy way to get the gauges out on a 69, since they're held in from the back (trunk) side by brackets and knurled nuts.
You'll need to remove some of the defroster/vent plumbing for easy access, so try to do everything you need to while you're in there.
Dave
1969 911T Coupe
1972 911E Targa
Old 01-13-2006, 06:50 PM
Duke's Avatar
If your speaker grille is removable, that is the easy way. Just remove it & then remove the clock & work your way across to the others. You can do all this while sitting in the driver's seat.
Old 01-13-2006, 07:50 PM
zmayne's Avatar
I don't have a speaker in the dash, so looks like the trunk is the only way.
Old 01-13-2006, 07:53 PM
