+ lurking - contributing
930 PPI test results, imput requested
Just got the compression/teakdown test numbers back on a 1987 all stock 930 in Florida with 75,000 miles. Unfortunately the test was done on a cold engine, 65 degree room temperature. Plugs a bit black but not extreme. What are your impressions?
Cyl 1: 120lbs comp, 10% leakdown
Cyl 2: 120lbs comp, 12% leakdown
Cyl 3: 140lbs comp, 12% leakdown
Cyl 4: 130lbs comp 02% leakdown!!
Cyl 5: 130lbs comp 12% leakdown
Cyl 6: 130lbs comp 10% leakdown
Tester said he could not hear any air seepage in intake or exhaust. Car drives well except for cold start smoke and high RPM pinging supposedly from "old/poor quality gas".
Old 01-14-2006, 07:18 AM
Nine9six's Avatar
William,
Seems to me that the compression/teakdown test was performed in all the conditions of how NOT TO perform compression/teakdown.
Vehicle should have fresh fuel, up to normal operating temp, driven briskly prior to performing the test to help blow out any carbon deposits and assuring best valve seating.
As stated, these #'s seem low on the compression, and high on the leakdown. I believe that leakdown should be <10%, with variance between cylinders around 3-4.
IMHO, based upon the stated conditions, I think this test was a waste of time and money.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 01-14-2006, 08:00 AM
I asked the tech if they could do it with a warmed up engine, and the excuse was the amount of time it took to remove accessories to reach the plugs, especially the left side. I was surprised since they have a SCCA ITC/ITB racing pedigree
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 01-14-2006, 08:19 AM
possible waste of money: $421.67
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 01-14-2006, 08:20 AM
GOT TURBO..
MobileWrks's Avatar
** Better to find out **
(WOW) Thats for the PPI????? Holly C$#@.... Some times its better to spend that, and not have bought it... Then to buy it and need and engine later.......
FYI... A shop that complains on amount of time it took, well, i do those alot, and leak down and Comp test in 2 hours.... looks like they billed you for 4+ ..??????
Is it a Porsche only shop, or do they have every list of european car there......
Good luck on the hunt for a turbo... Pray to the PorscheGods
Old 01-14-2006, 10:50 AM
I find alot of shops in Fl shoud not be working on turbo cars far less trying to do PPI. But if you are out of town what are ya going to do.
Good luck with car hunt
Old 01-14-2006, 11:09 AM
jrl jrl is offline
With a lower nominal compression ratio, shouldn't 930 numbers be lower than the 150-160 psi I hear about for NA 911s? Taking 130 as the average of your results, looks like the variance was about +/-7%.
I bought an 86 all-stock 930 that showed ~12% fairly evenly across all cylinders and even compression, smoke puff on start-up. A few experienced Porsche specialists have told me that they worry when leakdown gets to 20%. Less is better, but for me 12% wasn't a killer on an unmodded car. A future rebuild will come quicker at 12% no doubt, but here the condition and the price of the car offset this.
If the car's a good deal and you like it, it'd be well worth a second PPI from the best, most conservative shop you can find that'll test it right, especially re purported gas-related pinging--worst that can happen is you find a good shop to care for an eventual purchase. If the PO gets uptight, keep shopping.
Old 01-14-2006, 12:12 PM
jrl, how many miles on your 930 engine when you had the engine tests?
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 01-14-2006, 01:12 PM
Nine9six's Avatar
William,
Was the $421 just for compression and leakdown, or did the tech inspect the whole car, and give you a written analysis of his findings?
P.S. Doing a search on this board has saved me more $ than I care to think about.
96 993 C2 (Current)
Old 01-14-2006, 01:21 PM
MobileWrks, the shop I used caters to imports, with good VW & Porsche experience. They charged for four hours of service to the 930. I felt that was too much time, but it was an out of town inspection near the purchaser...convienent, costly with mixed results
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 01-14-2006, 01:23 PM
Author of "101 Projects"
Wayne 962's Avatar
How much is this car?
The compression test looks okay to me. The leakdown numbers are high and potentially suspect - not ideal in my mind, although the test wasn't done when warm (which is also common too).
What is more worrisome is the pinging - as that can easily destroy an engine very quickly. If the car has be detonating (pinging) for a long time, you can have engine damage...
-Wayne
Old 01-14-2006, 01:24 PM
Nine9six, the cost covered compression test, leakdown test, plug evaluation, road test and written report
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 01-14-2006, 01:25 PM
I would get anothe ppi!
Wayne, the car is $25,000
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 01-14-2006, 01:26 PM
Nine9six's Avatar
William,
Now I am confused...Are you the seller, or the prospective buyer?
96 993 C2 (Current)
Old 01-14-2006, 01:28 PM
From reading around this board, Wayne's awesome books, and 911turbo.com, a hot engine test is not that difficult. If I purchase this vehicle, I will do it myself at home! i am expecting more uniform numbers.
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 01-14-2006, 01:36 PM
Nine9six, I am a potential buyer, sorry for the confusion
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 01-14-2006, 01:37 PM
jrl jrl is offline
William930t,
My car had 57 kmiles. If the car is in excellent shape, $25K sounds like a very good price. I paid much more than that for mine, but this included $4300 of documented work the selling dealer put into it (and of course he was a dealer). Presume the first PPI covered the many other items (body damage, paintwork, transmission, electricals) that are costly.
The pinging could be a significant issue and is well worth a few hundred dollars more due diligence. $25K might be a great deal or you-get-what-you-pay-for.
Old 01-14-2006, 01:52 PM
Early_S_Man's Avatar
Porsche Crest
I guess the proverbial 'asbestos octopus' is extinct these days ... or some technicians in Florida are just lazy ... and have no shame, to boot! $421.67 is highway robbery for an incompetent job! I think a talk with the shop owner is in order ... the lame excuse calls for some 'public relations' cutting of the final bill!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-14-2006, 05:13 PM
Driver
Noah930's Avatar
$421: way too much to pay for an inadequate test. Especially when their excuse is lack of time to do it properly. I also purchased a car out of town. The local shop gave me ridiculous numbers for compression (in the 70's-90's). I told the PO they were WAY off. He agreed, as did the shop when it was brought back to their attention. They did the second run gratis, and my numbers were also in the same range as yours (both compression and leakdown). No pinging on my car, though. My bill came out to about $250. In the end, FWIW, I paid a few thousand more than your asking price.
1990 Black 964 C2 Targa
Old 01-14-2006, 05:52 PM
