Part Fabrication Help - Blower motor adaptor- Need part fast!
Looking to fabricate the custom part below to mount the heating fan onto Grangier blower motor.
How much to fabricate? Any shops out there that can make it in the next few days and ship? material can be Aluminum. Thanks .
If no one here can fabricate quickly then try http://www.emachineshop.com/ .
Warren & Ron, may you rest in Peace. |
Senior Member
How about you make it yourself??? This is not rocket science!
Go to Home Depot, buy some a drill, bits and a hacksaw if you have none of the above at home. Tap at the same place along with a tap handle. Go home and scribe the lines on the metal and get to work. Tapping the hole is easy, just go slow and after a half turn, back the tap out a bit to clear out the hole. Oil as needed. Its not difficult. Anyone good with their hands should have it done in an hour or so. A descent machine shop or home shop could have it done with a bandsaw and drill press in under 15 minutes. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Diss Member
Gee, I just used a bit of tubing to increase the diameter of the motor shaft so it would fit.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
i tried it....it took forever to try and drill a 1/4" hole in a piece of aluminum!
Diss Member
on ramp,
if you don't want to fabricate it yourself, however you could make that part (if you have some alumn. , brass, delrin, etc.) with a file, drill, dremel, square, drills, and taps. you may want to add a few more details of the "blind" details, note tolerances if critical and insure your flipped view s are correct (vs. a euro flip). drills must be sharp, you don't cutting fluid for alum, simply back the drills and taps out every turn or two to clear the chips |
Plenty of blown-up heater blower motors out there. Maybe if you throw a quick post in the parts for sale forum, some nice soul might take pity on you and sell\send you one,
ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Try a sharp drill bit.. I just had to say it..
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. |
