Chip installation instructions
I have a montronic box from a 964.
I want to take inventory of what chip is in inside.
I didn't install it so I don't have instructions to get to the chip.
I've taken the cover off, but the rest is not all that obvious.
I've search for over an hour, but cant find a thread on this.
I've seen some threads with some tips, but they are mostly adding info to whatever instructions people are already looking at.
There must be a thread, or a link to someone's site that has the details.
Thanks!
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 01-15-2006, 06:22 AM
Steve Wong has good info here. Also has a great chip. Ken
http://www.911chips.com/C1INSTR.pdf
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 01-15-2006, 06:40 AM
The technical forum has an article under "Fuel Injection" that illustrates and discusses steps to take to remove and replace a chip.
Tony G
2000 Boxster S
Old 01-15-2006, 06:44 AM
Thanks, I think this is all I needed.
Bill Miller
81 Targa Guards Red
Old 01-15-2006, 06:50 AM
Losening the top circuit board was a little more involved.
The 964 montronic box has 55 terminals on the main connector.
The top 18 are actually part of the top board. There is a tang on both ends inside the big connector that need to be pried out with a small screwdriver. It's not what is immediately assumed. By prying these out a bit it allows the back edge of the board to be lifted higher which in turn allows the board with the top 18 terminals to be slid out the back of the connector. Then it can be folded open on the ribbion cable like a book.
After opening it up I found an GIAC chip. Never herd of them, but they seem to support a lot of applications.
What's the deal with these? Good, bad?
Bill Miller
81 Targa Guards Red
Old 01-15-2006, 08:52 AM
RETIRED
Joe Bob's Avatar
If you want a dual, performance/stock chip for the 964 talk to Ingo at 3.6@cox.net
Flip of a switch changes the mapping.
2012 ML350 3.0 Turbo Diesel
Old 01-15-2006, 09:31 AM
