SMC SMC is offline
O2 sensor cat bypass?
Do I need to run an O2 sensor on an 1988 3.2 911, with a cat bypass?
1988 911 Carrera
1970 911T
1972 911E Roller
Old 01-19-2006, 09:31 AM
Don Plumley's Avatar
If you have a stock DME, yes. If you have some other engine management system, unknown.
Most good cat bypass pipes have an O2 bung hole.
Don Plumley
M235i
Old 01-19-2006, 09:39 AM
Large Registered Member
PatrickB's Avatar
It'll run without it, but you'll see about a 20% drop in fuel economy....
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 01-19-2006, 09:56 AM
Re: O2 sensor cat bypass?
No you do not need to run an O2 sensor (the car will run), BUT, the car will run very rich and you will not pass your smog test. Definitely not the optimum
Mark
1987 Carrera
2018 GMC Sierra Denali 2500 Duramax
2012 Harley Davidson FLHX Street Glide
Old 01-19-2006, 09:58 AM
fuelie600's Avatar
You can buy the bung (fitting) for about $10 from an auto parts store and weld it in. It takes a few calls to find a place that has them, but they are available.
Evan
1987 sun roof coupe
Old 01-19-2006, 11:54 AM
PatrickB's Avatar
SMC~
Don't know if you've purchased it yet, but you can opt for the bypass that has the bung hole in it already. Mine has one...
I can't believe I just said "bung hole."
Old 01-19-2006, 12:39 PM
ThePointman's Avatar
Send a message via ICQ to ThePointman
I just couldn't resist getting in on all this "bung hole" chat ...
Hey, he said "Bung Hole!" LMAO
Old 01-19-2006, 06:53 PM
