Counterclockwise?
Phone number for a flat bed tow truck.
Find one that will pick you up hundreds of miles away day or night. $50/hr both ways, but worth it.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
I never leave home without the extra long 3mm allen wrench for the idle mix screw, a flash light to find the adjustment hole in the dark, and an extra wheel lock key some where in the car.
I treat the factory tool kit as cosmetic items except for the spark plug socket and the fan pulley tool. Everything else is just there to raise the value of my car upon resale.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
DME relay and possibly a clutch cable (previous experience).
Warren, only you, I and a few others. Hehe. I would want real-time logging and diagnostics. Best, Grady |
clutch cable is good. I have an extra cable and clevis pin, etc. in my 911 right now.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
I've heard it said that the Porsche minimalist toolkit is....a cyanide capsule. I've also wished I had that tool on an occasion or three.
Mark '88 Carrera GPW Sunroof Coupe '82 SC Targa (RIP) |
I now know of the ultimate upgrade for the factory 911 toolkit.
I had never heard this before, but watching a video on the net just now I heard that the toolkit for the Mclaren F1 contains "Facom titanium spanners". I'd love to have a set. I'm guessing that they are probably as expensive as they are hard to find.
Interesting
IMO, #1 on any carry list would be a spare fan belt and the needed tools to change in case of belt failure. Keep driving with no fan belt, and an air cooled engine will suffer damage in short order.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
drag racing the short bus
The Terror of Tiny Town |
Very true, dd74...the factory kit in the pic sure wouldn't help me in the case of a broken belt....
Speaking of the factory kit. Does anyone know where I can get a 24mm factory style wrench for removing the alternator nut?? New alt is 24mm my old one was 22mm..and it just won't fit.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
10 Best Tools of All Time - You had to ask
Us former British Car owners long ago faced this quandry and through many, many years of diligent research discovered that you only need 10 tools. Fortunately for you, our list is good for all Marques regardless of year.
"Forget the Snap-On Tools truck; its never been there when you need it. Besides there are only 10 things in this world you need to fix any car, any place, any time. 1. Duct Tape - Not just a tool, a veritable Swiss Army knife in stickum and plastic. It's safety wire, body material, radiator hose, upholstery, insulation, tow rope, and more - in an easy to carry package. Sure, there's prejudice surrounding duct tape in concours competitions, but in the real world, everything from LeMans-winning Porsches to Atlas rockets use it by the yard. The only thing that can get you out of more scrapes is a cell phone. 2. Vise-Grips locking pliers - Equally adept as a wrench, hammer, pliers, baling wire twister, breaker-off of frozen bolts and wiggle-it-till-it-falls-off tool. The heavy artillery of your tool box, locking pliers are the only tool designed expressly to fix things screwed up beyond repair. 3. Spray Lubricants - A considerably cheaper alternative to new doors, alternator, and other squeaky items. Slicker than pig phlegm, repeated soakings will allow the main hull bolts of the Andrea Doria to be removed by hand. Strangely enough, an integral part of these sprays is the infamous Little Red Tube that flies out of the nozzle if you look at it cross eyed (one of the 10 worst tools of all time). 4. Margarine Tubs with Clear Lids - If you spend all your time under the hood looking for a frendle pin that careened off the pertal valve when you knocked both off the air cleaner, it's because you eat butter. Real mechanics consume pounds of tasteless vegetable oil replicas just so they can use the empty tubs for parts containers afterward. (Some of course chuck the butter-colored goo altogether or use it to repack wheel bearings.) Unlike air cleaners and radiator lips, margarine tubs aren't connected by a time/space wormhole to the Parallel Universe of Lost Frendle Pins. 5. Big Rock at the Side of the Road - Block up a tire. Smack corroded battery terminals. Pound out a dent. Bop noisy know-it-all types on the noodle. Scientists have yet to develop a hammer that packs the raw banging power of granite or limestone. This is the only tool with which a "Made in Malaysia" emblem is not synonymous with the user's maiming. 6. Plastic Zip Ties - After 20 years of lashing down stray hose and wiring with old bread ties, some genius brought a slightly slicked-up version to the auto parts market. Fifteen zip ties can transform a hulking mass of amateur- quality wiring from a working model of the Brazilian Rain Forest into something remotely resembling a wiring harness. Of course it works both ways. When buying a used car, subtract $100 for each zip tie under the hood. 7. Ridiculously Large Craftsman Screwdriver - Let's admit it. There's nothing better for prying, chiseling, lifting, breaking, splitting or mutilating than a huge flatbladed screwdriver, particularly when wielded with gusto and a big hammer. This is also the tool of choice for all filters so insanely located that they can only be removed by driving a stake in one side and out the other. If you break the screwdriver--and you will just like Dad and your shop teacher said--who cares, it has a lifetime guarantee. 8. Bailing Wire - Commonly known as MG muffler brackets, bailing wire holds anything that's too hot for tape or ties. Like duct tape, it's not recommended for concours contenders, since it works so well you'll never need to replace it with the right thing again. Bailing wire is a sentimental favorite in some circles, particularly with the MG, Triumph, and flathead Ford set. 9. Bonking Stick- This monstrous tuning fork with devilish pointy ends is technically known as a tie-rod separator, but how often do you separate tie-rod ends? Once every decade if you're lucky. Other than medieval combat, its real use is the all-purpose pplication of undue force, not unlike that of the huge flat-bladed screwdriver. Nature doesn't know the bent metal panel or frozen exhaust pipe that can stand up to a good bonking stick. (Can also be use to separate tie-rod ends in a pinch, of course, but does a lousy job of it). 10. A Cell Phone"
LOL
Was that a Peter Egan list ????...sounds like him...
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
in addition to the excellent items above:
lots of extra fuses - variety fan belts flashlights -- big and small, plus batteries gloves rags / towel stubby (small) screwdriver -- for close quarters
Dan '87 911 Carrera - Cabriolet |
Dynamo flashlight, 1 minute of work = 30 minutes of light! And you could charge your SonyEricsson phone with it
Fonz, I have an assorted package of fuzes, and it may be a good idea to have an extra relay for the fuel pump.
Gary
1985 911 Carerra Cab 3.6l 1998 Dodge Ram 2004 Toyota Tundra Quad Cab |
