Bollweevil
CIS Question (dumb)
'74 2.7L CIS
Immediately to the left of the CIS FD head, there is a heavy wire piece (2 or so inches long) with a loop on the top. This wire sits in the FD body between the FD head and the air intake boot.
I can't find any reference as to what this is or it's purpose but feel very confident someone on the board can enlighten me.
it is part #45 in this diagram: http://www.pelicanparts.com/911/911_Parts/1974-75/2-3-1.JPG
thanks,
Jack
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 01-16-2006, 06:18 PM
Kirk911SC's Avatar
Mixture adjustment tool.
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '04 Subaru WRX wagon - Sold
Old 01-16-2006, 07:00 PM
ianc's Avatar
It is just a wire piece with a rubber plug on the end that covers the mixture adjustment screw.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 01-16-2006, 07:25 PM
Unregistered
sammyg2's Avatar
While I have never seen the item described, but i have heard the folklore that it does exist, much as hobbits exist and unbroken 914 plastic fuse panel covers.
There is a hole in the top of the fuel distributer that is used to adjust the fuel mixture with a 3mm hex wrench.
As the fairy tale goes, there was a rubber plug with a wire on it installed from the factory into this liitle hole. The purpose was to keep unfiltered air from entering said hole.
Now back to reality, all the CIS equiped engines i have studied or worked on either had nothing in this hole, or maybe a golf tee.
Sooooo..... some folks actually beleive the plug with wire exists, but most of us chock that up to the tooth fairy or santa claus.
You can tell us you have one but i still don't buy it. Maybe if you supplied a picture of this ellusive, almost unicorn type of item........
I'm not sure if I need one more beer or if I have had one too many. Only time will tell
Old 01-16-2006, 07:59 PM
Bollweevil
thanks for the responses. I should have been able to figure that out. There is a picture on the referenced site under testing air/fuel ratio that shows / explains this. I just wasn't connecting the two.
Sammyg2: I had no idea I possessed such a mythical part, perhaps Gandalf smiled upon this mere 911 of mine... I will film this part asap and post for the non-believers to gaze upon...
Within the greater scheme of things, one to few or two three more beers will matter little.....
http://members.rennlist.com/jimwms/CIS/CIShome.html
Jack
74 911 Coupe
Old 01-16-2006, 08:08 PM
Designer King
Paulporsche's Avatar
Keeping that (or a relacement) tool in place prevents sound pad particles and other dirt from clogging the slot in the mixture adjusting screw.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 01-17-2006, 06:32 AM
Mine has/had this part. I removed it to make the adjustment and it is on my work bench. I would bet this is how most of them found their way into folklore. I will reinstall tonight when I get home.
Kevin
'79 Coupe
Old 01-17-2006, 06:37 AM
Somatic Negative Optimist
Gunter's Avatar
These plugs came with many different Bosch CIS systems; you'll find them on old Volvos, etc.
I keep mine to plug the hole; it is secured with a little chain so it won't get lost.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-17-2006, 09:08 AM
bigchillcar's Avatar
yes, i too would love to see an actual pic of this mythical part.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 01-17-2006, 09:15 AM
safe's Avatar
I do have a picture of mine, but it is on my work computer.
I'll post a picture of it tomorrow.
Magnus
Old 01-17-2006, 11:25 AM
Bollweevil
Apparently Gunter has the right idea, secure it with a small chain.
The mythical CIS plug as original equipment:
Jack
74 911 Coupe
Old 01-17-2006, 02:56 PM
oooooh...ahhhhh!
ryan
Old 01-17-2006, 03:21 PM
Unregistered
sammyg2's Avatar
Looks photo-shopped to me
Old 01-17-2006, 03:36 PM
Bollweevil
have two, tree more beers sammyg2 and if you close one eye and look real close you will discover it's really just a big paper clip
Jack
74 911 Coupe
Old 01-17-2006, 05:16 PM
hey..i could take a beer..?
ryan
Old 01-17-2006, 06:35 PM
safe's Avatar
I actually took the pictures a few months ago to ask here what the hell it was!! I always read that it should be a hole there for an allen wrench but I had some form of built in adjuster...
Well, now I know better.
Magnus
Old 01-18-2006, 01:04 AM
