Oil Level Gauge
Can anyone explain how the oil level gauge works on a 993? I read the manual, and it says to sit at idle, engine warm, to get a reading, but mine sits down in the red. I've checked the oil level, it's mid way up on the twisted section. I checked while idling, level, engine warm....The manual shows a check for the gauge, did that, don't think it's the gauge. Is there a sending unit I can check? Just ignore it and keep checking the dip stick?
Appreciate any advice,
Mike
1995 993 Polar Silver cab
86 ROW cab, gone but not forgotten.
1948 Indian Chief
1989 FLHS
Too many old british race bikes.
If it doesnt leak, it must be out of oil !
Old 01-17-2006, 01:56 PM
Send a message via AIM to johncarlos2003
Try driving the car for 15 minutes then sitting at idle- should go up. The car really must be warm- not on for a few minutes- the gauges are often inaccurate- always use the dipstick even icf your gauge shows ok-
Old 01-17-2006, 02:21 PM
Thanks, I'll keep checking it with the dipstick. I'm old school anyway, I'm amazed by this engine, not a single drip of oil on the floor after a hard 300 mile run....
Mike
1948 Indian Chief
1989 FLHS
Old 01-17-2006, 02:46 PM
fogcity's Avatar
Let the engine get hot, not warm. Check when idleing on an even surface.
1984 Carrera Coupe
Old 01-17-2006, 02:52 PM
Thanks, I'll try it. Do you know if its a float gauge, or what? that sends the signal?
Mike
1948 Indian Chief
1989 FLHS
Old 01-17-2006, 03:16 PM
ianc's Avatar
Float gauge on the side of the oil tank behind the RR wheel.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 01-17-2006, 03:25 PM
Pete000's Avatar
I have found that the engine has to be really hot for the guage to work. When it is totally warmed up the guage reads accurate only at idle. The difference between the low and the high level is about 1.25 quarts. I drive the car till it shows less than half and then check the dip stick and it usually shows half way between the marks. I add about a quart at that time.
That guage is kind of dumb.
Work to Live, don't live to work...
Old 01-17-2006, 03:26 PM
Administrator
Jack Olsen's Avatar
It's a float gauge, and it's measuring the level in the tank while the tank is (both) actively draining and being refilled. Understandably, it's very sensitive to oil temperature. Always trust the dipstick more than the gauge, and remember to check it after you've driven the car, not before, so you know you're up to operating temperature.
Old 01-17-2006, 03:34 PM
Thanks guys, I'll keep watching it!
Mike
1948 Indian Chief
1989 FLHS
Old 01-18-2006, 06:39 AM
