Weber carb question
I have a set of 40IDTPI3C1 carbs from a 914-6 I am putting on my 6 with a 2.7 engine. The engine has 2.7 euro p/c's, the 35mm port S heads, and Solex cams installed. Stock heat exchangers with a sport muffler.
I plan on jetting the carbs as a base line per Bruce Anderson's book using F3 emulsion tubes, 135 mains, 145 air corrections, 34mm venturis. I have 45 idle jets, but think maybe 60's would be better? Also looking for a good place to purchase all the jetting. The car is in Ohio, so altitude is not an issue.
BTW, anyone hazard a guess on which plugs to run?
Thanks!
Bill
Old 04-18-2014, 05:35 AM
Check out. youroil.net for carb parts. Nice guy to deal with
Old 04-18-2014, 06:16 AM
ganun's Avatar
I've dealt with Pierce Manifolds for Weber parts, lots of tuning info as well.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 04-18-2014, 06:47 AM
Bill,
You can also contact any PMO dealer for Weber parts as most of them keep such things around.
F3 emulsion tubes are NLA so you may need to use something else. Idle jet size depends on venturi size so one would need to know that before making a recommendation. The 914/6 ones are too small for any 2.7.
I'd use either NGK BP6ES or Bosch W6DC's for street use. One step colder for track days.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-18-2014, 08:28 AM
I'll be using 34mm venturi's for the 2.7.
Thanks for the info! Just finishing up the engine now, won't be too long, I hope!
Old 04-18-2014, 09:25 AM
Vintage Owner
Jack Stands's Avatar
I recently had my 2.7 rebuilt with RS P/Cs and S cams at Supertec. After dialing it in on a dyno (running premium gas with 10% ethanol), we ended up with 34mm venturis, 155 main jets, 70 idle jets, f26 emulsion tubes, 180 air correction, 150 idle bleed. Running an Electromotive ignition if that makes any difference.
Good luck on your setup.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 04-19-2014, 05:18 AM
haycait911's Avatar
I just some price comparing. these guys are insanely high with their prices.
Youroil.net
Old 04-19-2014, 06:28 AM
