Adding Lightness - gut the fish
Today's project was starting to strip the interior. Here's the result:
And how it starts adding up: Rear seat backs: 5# each Rear seat bottoms: 4# each (including some pad) Rear carpet and pad: 20# Rear parcel shelf and speakers: 11# Rear seat belts: 1.5# each Front seat belts: 2# each I lost over 55# from my rear today. (Honey, does this make my butt look big?) Let's say 10# for the RS carpets in the rear area - so a net of #45. From yesterday's work: Door Panels: 10# each, net 8# with RS Panels Seats: 48# each, net 30# with Sparco seats That's about 120# so far...
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
YES!
AC gone yet? big battery gone yet? Steering wheel gone yet? Spare gone yet?
...sick with gearheadia |
AC - No, very small weight penaty for drive home cooling.
Big Battery - planned. Steering Wheel - yes, new Momo Mod 07 ready to install. Spare - out when I get to the track.
That wil be a fun car! Thanks for the information!
Congrats, Doug
1971 RSR - interpretation |
And 17# for the front carpet/sound deadening...
Now in 993 land ...
Well, a nice roll bar or cage will add some more weight back - the diet jojo effect!
George |
Wer bremst verliert
AC is a 60 lb penalty...
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy Last edited by JohnJL; 01-20-2006 at 02:26 AM.. |
durn for'ner
You sure you wanna add any carpeting in the rear ? The bare metal kind of adds a bit of racing look. Cool IMO.
Markus Resident Fluffer Carrera '85 |
GFCC
I'm on the same path Don. Looks very familiar. I have a "Modified" muffler and I think one of the best things about this project is how the car sounds on the inside without the sound deadening pads. Very race car like.
I left mine bare metal and have removed the door panels and glass. I will replace it with plexiglass for those cool mornings. My ride height changed a lot (raised 2-3 inches) after removing the weight, so start looking into new springs if they sren't adjustable on your car. Have fun and keep us posted on the progress.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
Yes, the rollbar does add back in some weight. Hopefully we'll still be at a net loss. Wavey - I was using a 10# = 1Hp. But as we know, lighter weight have better gains in terms of faster accelleration, deeper braking and less weight for the suspension to handle. Sure would be nice to get under 3000#.
Certified Pre-Owned
'84 Carrera Coupe |
Weight between the wheels, especially when it is low is the least significant kind of weight.
Most of these cars have to run a lot of ballast to make class weight. That's sort of good because the weight is taken from the ends(extremely important) and added low in the middle. Don if you could, I would love a clean shot of the wiring at the top and passenger side. I can't get at mine till I take the rollbar out. I am trying to nail down the rear widow and brake light wiring connectors.
As for A/C, I'm with Don. Where we live and the tracks that he's going to, it's not un-common to see 110-115F. in the Summer. So I say unless you're trailering, keep the A/C, no mater what the weight penalty (17 vs. 60lbs.)! Don, thanks for keeping us posted. Even though I'm not tracking anymore, I'll have to check your car out one of these days when you're at Thunderhill. |
Bill - PM me with your email address and I'll post links for the pictures.
Yea, weight behind the rear wheels is best. With the WEVO motor mounts and cat bypass, that will take out about 25#. I'll eventually cut out the sunroof and replace with a CF panel. Come see it anytime Matt. Maybe in another year or so they'll let me take passengers.
Wer bremst verliert
Wow, 110-115...bad news to be running AC on an aircooled engine in that eat if you get caught in traffic!
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
The ratio for weight loss to equivalent HP gain dependds on the weight o the car that is a heavier car like the 993 benefits slightly more than a lighter car like an SC or Carrera. Or at least that's what my math is telling me. A 2,756 lb Carrera with 217 hp stock has a weight to hp rating of 12.7 (lbs devided by hp). If you knock off 100 lbs and assume the same lbs per hp the gain is 7.9 hp. At least that's what my math works out to and I was not a math major soooo could be wrong.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
PRO Motorsports
BTW, the A/C weight penalty is closer to 40# for the 964/993. The compressor weighs 14#, and the rest is from the condensor and fan and the evaporator core. The lines are aluminum, and the evaporator is integral with the HVAC. It's a much lighter/simpler system. Also the majority of the weight from the A/C is in front. The compressor is very light, and the bracket is integral with the engine mount, and is hollow aluminum. Oh, and it actually works!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Tyson, Do you know if the 993 compressor can be used on a Carrera and also can it be run on R12? Thanks
I was watching some show on speed vision awhile back it was about how lower weight improves performance and they went thru all math BLA BLA and said that a loss of 100#'s is equal to about a 15 HP gain. So a performance improvement equal to an estimated 18 HP increase seems plausible.
1978 race car scca GT2 1998 C2S sold 1996 C4S sold 1973 911 T restored with 2.7 RS running gear 1970 911 E Project |
Now in 993 land ...
Well, Don mentions it already, there is more advantage than just straight line acceleration with a lighter car. It is nice if there is less weight that wants to go straight in a turn.
3000 lbs is your goal? YIKES! What the heck is so heavy on a 993? My SC is 2575 lbs, if I remember right, and that's with hardly any lightening, besides a/c removal. I still have the truck battery, for example. George |
