Trying to remove bilstein cartridge from 88
I’m trying to remove a Bilstein cartridge from a Boge strut on my new to me 88.
The green outer sleeve slid out. But the inside part won’t budge. I’ve gently tried to tap on the reinstalled top washer/nut and smacked around in the strut with a dead blow. She seems really stuck. I’m afraid to get medieval on it and damage it. I’m trying to get it apart because I suspect the cartridge is incorrect to the strut. There is side to side play in the strut/cartridge when the gland nut is tight. Cartridge F4-P36-0114-HO Boge 911 341 041 02 Any advice? ![]()
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!! |
These things are supposed to just fall out, right? Not retaining pins or anything?
Joe |
The gland nut is the only thing holding it in. On mine I had the spindle off and for the side that was leaking I had to hit the spindle with a large mallet really hard while holding the strut. Eventually it released. However if the strut housing is bent or dented it’s nearly impossible to get it to release.
Doug 74 Carrera Targa #9114410208 |
You need to remove the bolt that goes through the bottom of the strut as pictured to remove. This separates the insert from the housing/ball joint.
On my 85, I just removed the large "nut" that is a pain to remove on the top of the cartridge. Your photo shows it as removed. On my 85, the insert just pulled out with a lot of oil dripping off. I had to swab out the oil with paper towels.
Maybe the 85 does it different. I did NOT want to remove my strut, just the insert. ![]() ![]() Many people just use a large pair of channel lock pliers. I can't image what is holding your insert in place.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Correct, might be easier to remove it from car and put in a vice.
It’s a boge strut there is no bolt holding the insert.
I had the same issue, it was basically stuck in there due to suction and I could not remove it. Tried a method I found on the pelican board using a piece of PVC pipe that is the right diameter on the top part, put the bolt and top cap on and used an impact wrench and it pulled it right out.
---- 1981 911 SC Targa Santa Fe, NM |
GH85 - Some people use light weight oil to help with heat transfer from the shock itself. If yours wasn't leaking that's why it was there.
I just replaced the inserts with new Bilstiens. I have owned my 911 for 30 years. I have a really hard time finding anything I can blame on the previous owner anymore.
PCA Member since 1988
Yeah, I hate that guy too. After 33 years, there isn't a part on my car that my hands haven't touched. I have to look in the mirror frequently.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Yep, and on occasion say what the heck were you thinking ya dummy.
OK, I like Jaxx's idea but I had to think about it. A PVC cap with a hole in and washers might work but might split. I'd suggest a cast cap instead. If you go that route get one big enough you can use the gland nut to protect the threads.
