Yet another perfect WEVO product.
I tested the new prototype WEVO trans mount bar this last weekend. It worked perfectly with my WEVO Semi-Solid motor mounts. After removing my old OEM trans bar mount and looking at the old cracked rubber, no wonder it was hard to shift while coming out of low gear/high exit speed corners. The trans/and motor would shift to one side. That little movement on the tranny/motor can wreak havoc while trying to shift. Well, not anymore. It worked like a champ.
I did some personal "Quality Control" and flew off Willow Springs at around 120 mph. It held up nicely ![]() Here are some pictures of it installed on the car. Very easy to install. The quality is what you would expect from WEVO. Typical WEVO Jewelry.
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 |
Scheez your car is clean under there - thats a little neurotic dont you think :-))
Looks great, I really noticed a diff on the street when I put new sport/ solid mounts in my car.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Administrator
Beautiful.
Of course, Hayden and his company have us expecting nothing less.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Indeed, Hayden seems to have a great niche carved out. I just got some new WEVO parts, and they are SPECTACULAR!
Wish I could go into detail....... but I will in due time...
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Hehe, I know the feeling
Any chance of a G50 version? I put sport motor mounts in but still have the old stock tranny mount. I haven't seen any sport replacements available for the G50.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Licensed User
I was just trying to figure out where I could get something like that for my new tranny.
Ok, I just might have to stop frequenting this site... It is costing me too much $$$... When do we get to do a group buy on those sweet Wevo motor/tranny mounts!!!
GruppeB #935 84 Carrera Targa B.A.S.T.A.R.D. (for sale) 82 SC RSR Project (on ebay) 95 Dodge Ram 2500 03 Toyota 4runner |
drag racing the short bus
Nice. I echo Noah's questions. As well, is it lighter than the stock mount?
The Terror of Tiny Town |
Chad I swear if you keep your transmission that clean we'll kick you out of Gruppe B
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Whats the big diff between this and new mounts from Porsche?
74 911s neverending story. two feet and a jetta for now. |
Information Junky
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Another question...would you all who have both the WEVO trans and motor mounts say they are too firm for the street?
Zach
'86 Carrera coupe '03 GTI 1.8T '04 919 Hornet |
What about the install? Whats invovled putting this in? I am having similar problems as you describe and looking for a similar solution.
1983 911 3.6L - NASA GTS-3 class 1998 Boxster - PCA SpecBoxster, NASA GTS-2 2003 996X51 - NASA GTS-4, PCA GTB 2003 996 Carrera 2 Coupe 2003 Ferrari 575M |
As Noah mentioned, I'm a little confused about the part; doesn't the 915 tranny cross member allow one to change the mounts? I know the G50 has the mounts built in, but it looks like Plavan has a 915.
J.P. |
Bird. It's the word...
Hayden??
John Forcier Current: 68L 2.0 Hotrod - build underway |
Chad, do you RACE that car or just polish it?
Where is the grease all over the trans, caused by it centrifuging out past those pristine blue gaskets? Just kidding. Hayden's stuff is the bomb.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Isn't that a 901 trans in Chad's car?
Hi guys,
Sorry, I was out polishing the underside of the car . That is a 901 tranny. A late mag case (the only 901 case a Guard 80% LSD will fit in at the moment). The OEM 901 transmission cross bar rubber mounts are not removable. So if you have a 901 you are stuck with the old cracked, rotting rubber. That is unless you drill out/burn out the old rubber and weld in metal mounts. The blue material is the same that is on WEVO's semi-solid motor mounts. There are different schools of thoughts on solid metal mounts anywhere on the drive train. Metal mounts distribute harmonics throughout the motor, induction system, and transmission. I'm no engineer, but I do not want to risk any type of damage to my expensive race builds. I'm not sure about the 915 tranny questions. I do know they are removable, unlike the 901 transmission. I'm sure Hayden will pop on this thread and answer the technical questions. Why is my under side so clean? I just had the motor, and trans out. The trans had some new gears put in and an LSD. Media blast the outside of everything then clear coat . Wipes up nicely.
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 Last edited by Plavan; 04-26-2005 at 08:37 AM.. |
