Porsche-pa
75Carrera's Avatar
Wipers start when I hit a solid bump?
When my 75 Carrera encounters a stiff bump sometimes the windsheild wipers will start up as a direct restult of the jolt. Is there a easy remmedy for this without taking the whole assembly apart? Its not a serious or even frequent problem but it is annoying...
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 01-30-2006, 12:23 PM
Mine used to come on with the squirter shooting in a hard turn. Nothing like a high speed DE corner needing full concentration and having the wipers and washer come on mid turn. Anyway, I replaced the wiper switch with a new one. Problem solved. There is probably a short in the switch causing this. You might get lucky and be able to fix it, but it still will need to be disassembled. I would suggest you just put in a new one. It is a relatively easy job.
Tony G
2000 Boxster S
Old 01-30-2006, 12:36 PM
Yep, it's a switch problem. I believe same basic problem as the common issue with headlight switches.
Old 01-30-2006, 12:40 PM
Porsche-pa
75Carrera's Avatar
Is the switch difficult to get to and repair or replace? I can sure see where a switch would be worn after 31 years of loyal service!
Also rans...
Donny
Old 01-30-2006, 12:43 PM
Actually it is pretty simple. On my car (86) there is a plastic cover housing the windshield washer arm on one side and the blinker arm on the other. Remove the cowl, undo a couple of screws, unplug the wire harness under the dash, slip it out. Do the reverse for install. Very straight forward.
Tony G
2000 Boxster S
Old 01-30-2006, 12:47 PM
My 75 carrera did the same thing, I could not find the the org.74-75 switch with the older lettering, so, when I replaced mine I went with the later 77 onward style (hooks up the exact same way).
I also did the turn signal switch, the org. turn signal is still aval. with the green and black letting correct for a 75 carrera. Look around you can still find this one...,
do them one at a time, less confusion. make sure to use the little star washers with the screws that hold the switches down so they won't start to wiggle after a few months
Old 01-30-2006, 03:17 PM
Porsche-pa
75Carrera's Avatar
Thanks Carrera1975!
Excellent Carrera1975. Sounds like something I can do myself. Thanks
Do you know the production number of your 75? Mine is #215 Here's a couple of pics. I'd like to see yours.
Donny
Also rans...
Donny
Old 01-30-2006, 03:45 PM
