Name This Strut Brace
I have this strut brace that was installed by the PO long ago. There isn't any markings on it, so...... Who make this and where could I get one?
The ones I've seen all bolt on the front fenders on top of the strut. Are those better or is this brace on top of the shock better?
Bill 997.2 |
Monkey Wrench
I think that strut braces are supposed to stiffen the body. I don't think they should be connected at the top of the strut nut.
Bill,
If you decide to upgrade let me know, I would be interested in that strut bar for my early car that doesn't have the three bolts for the other strut bars. It would save me from having to fabricate one. Thanks! Mike
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
vanwyk4257,
I don't plan on upgrading, but if I do I'll keep you in mind. I was just looking for something for the other car. The way I see it is, yes, the ones that uses the three bolts around the strut would definitely stiffen the body. Which is by far the most popular. The one I have shown actually ties the two struts together which in return "should" give you a tighter feel IMO. But I'm no expert, that's why the post. In other words both move together instead of independently. Or do you want them to move independently of each other?
Bill 997.2 |
Thanks Bill. If you can find any brand name or markings on it let me know. This is the only style of strut brace I can use on my car without modifying the body. I may just have on fabricated otherwise. I appreciate it!
That bar looks to be OK on that issue, but you're right about the bar only correlating the struts and not the struts in unison to the body as well. The best setups use monoballs which eliminate the strut movement relative to the body and the bar holds the body from flexing with a second, triangular member. I believe WEVO and Elephant Racing both address this well. Would the above bar help? I don't see anything negative about it, just falls a little short of the whole package. Edit: After seeing the close-up pics below, I'm not sure that all of what I said here is accurate. Last edited by Zeke; 02-02-2006 at 08:01 AM.. |
Why not modify that one slightly. Can you fab a bracket that bolts to one or two of the three bolts around the tower and tie it back into the main bolt at the end of the bar. Like a "V" on either end. Then you just need a longer bolt to tie the whole thing together.
Tony G 2000 Boxster S |
Walt is right I would pull that thing off. I think you are causing shaft bushing wear in the strut. No bar is better than one that limits the movement of the top of the strut.
It is usefull as a tool to pull the struts to max camber. But after the bolts are tightened holding the camber I think you should pull it off.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
I have a bar that looks similar at the attachment point, but is actually tied in to the body via the strut mount. The strut mount accepts the top of a Bilstein RS strut. The PO assembled all this a few years back, and says he got this and other stuff for the car from The Racers Group. I don't think there are any markings on the strut bar to indicate the manufacturer.
![]() I'm sorry I don't have any more information, I just thought this might be an interesting addition to the thread.
Jim www.jimsbasementworkshop.com (CIS Primer for the 911) (73 911T (RS look) coupe) (Misc. 911 Parts for Sale) |
OOh Jim that is sexy!
Jim,
Excellent Post!!!! Thank you very much for that. Here is a link to that exact strut tower brace. www.theracersgroup.com Then click on Performance parts Suspension Components Strut Braces Then 911 Strut Brace That takes you to this pic: http://www.theracersgroup.com/parts/suspension/strut_braces/911%20strut%20bar.jpg I wonder what those are going for these days? Might be worth a call.....
Bill 997.2 |
71 911 2.2 73 510 V8...350 74 celica 18rg 76 911s |
My brace is identical to Jim's. I gotta say, I've been very happy with it. But my '87 has two very large washers with a busing between them. Like this from this link:
Strut Brace Installation So the brace that I have and the one Jim shows probably won't work with my '87? So on that car I'll have to use the surrounding allen bolts. SO...... I've seen some that use the rear two bolts, seen them using one rear bolt, now SLANTNOSE6 posted a pic using just the front bolt, I've seen using all three, and I've seen Weltmeister using all three PLUS the top of the strut. I don't even want to get into the triangular ones. That is for another day. Just about every combination known is out there for sale. They all do the same thing, but is one superiour over another? I'm leaning towards the ER one. That one uses one bolt.
Bill 997.2 |
strut brace
If you go to the Weltmeister website you can read their opinion on the value of tying both the body and strut together. Under load, they observe more movement in the top of the strut than the actual body. To me, this makes most sense, unless of course, you have immobilized the strut already,...ie. poly bushings or mono ball setups.
1988 911 coupe 1970 911t project 2012 Golf R |
Re: strut brace
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
What you want is a monoball and a bar between the strut towers.
