paslantnose's Avatar
I too decided to dive in today (had one valve begin to tick) and came back to this thread to refresh.
I decided to forego the factory method and went right to adjusting via Doug's method.
Armed with a .0025" feeler gauge, i simply used that to set them and adjusted until there was a very slight drag on the feeler.
Buttoned it all back up and went for a spin.
No more ticking valve (found 2 intakes slightly loose and 3 exhaust slightly tight).
Imagination but, it seems to pull minutely stronger from 3500 rpm on up.
Total time, 3 hours.
Honestly, ANYONE that can change their oil can do this !!!
Patience (and a few cold yueglings) is all it takes !
1980 911SC Slant Nose
Can you say MegaSquirt !
Old 05-27-2006, 12:54 PM
ninelevenick's Avatar
This is one heck of a thread! About one year ago, I adjusted the valves on my car for the first time and set them way loose. One month later, I adjusted them again, both times using the .004" hooked handle gauge tool. The second adjustment resulted in marked improvement, but when the oil temp. reaches about 190 degrees, one or more of the valves tick. There was one peculiar thing I noticed during the last adjustment though. I spent a lot of time on both the intake and exhaust for valve #2. The reason is because I would adjust the valve and then check for movement by pushing and pulling the adjustment screw (tappet?). After a while you get the feel of how much play there should be. Well, for #2, I would push and pull a few times feeling right, but then it would intermittently feel sloppy. The sloppy feel is difficult to describe, but there was more movement than there should have been. I don't have enough knowledge to come up with a reason or solution. Needless to say, I left the valve in this condition. Has anyone else experienced this? If so, I would be grateful if you could shed some light on this manner. Anyway, next week I will have time to take the valve covers off and try the method that has been covered by this thread. I hope I find some loose valves. Thank you for this thread!
Old 05-27-2006, 02:37 PM
khamul02's Avatar
So how many have used Doug's method?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 05-27-2006, 07:43 PM
Forced Induction Junkie
WERK I's Avatar
Snipernick,
You may have worn elephants feet on #2. I found this on my 930. I don't know if it's oil seeping in the pad and creating an hydraulic effect when doing a cold adjustment, cause once the engine got up to operating temperature, the tick was back. Replacing the elephant feet/adjusters solved the problem. So the problem may be coming from the feet themselves, not your technique.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 05-28-2006, 08:56 AM
oneblueyedog's Avatar
I'm doing it right now. Number one's intake let a .0025 slide in with a little side to side movement and the .003 would bow up and not slide in. The exhaust valve needed adjustment as the .003 went in easily. I set the valve with the .0025 on the heel to where there was an oil stiction of a drag to take it out like the poster above. I could slide it all around. When I tried the .003 feeler. It bowed like the intake and wouldn't go in. It's as easy as a 914 now. What I really like about the technique is that you don't have to waste time in adjusting a valve that didn't need adjusting. You can check it before hand. It's not possible with the elephant foot tool.
78SC coupe, Silver Metallic
Old 05-29-2006, 09:23 AM
We'll I've buttoned up the covers. I found only one valve tight. I sure hope I haven't burned it. #4 exhaust. Hope it's not stretching either.
I'd have to say it is more exercise to set them in that you have to stand up and down to set the feeler guage and pull it for feel. It was kind of tedious having to go topside for the intake adjustment and then below to drag the feeler guage (.0025). The drag on it is much looser than the adjustment tool method . The .003 just flexes when you have it set. On the valves I didn't adjust I checked the .0025 and made sure it went in nice and slick. Then i tried the .003 and the flex, and not going in told me that it was set.
Cut the time in half for me.
I'll post back for the running.
Old 05-29-2006, 03:28 PM
Another hint....
if you turn the crank in 120 degree increments "like we're told"...you'll be jumping back and forth on both sides of the engine ...going from one cylinder to another, in sequence.... on opposite sides.
If you turn the crank 240 degrees...you'll always stay on one side of the engine before yuo ultimately jump over to the other side...
This too saves some wasted time....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-29-2006, 05:25 PM
khamul02's Avatar
I wonder how long it will take for everyone to use this method!! I didn't even think about not having to adjust every valve.
Tom Hutchinson
Old 05-29-2006, 05:52 PM
khamul02's Avatar
At the very least, someone needs to write up a new tech article with this method.
Tom Hutchinson
Old 05-30-2006, 06:49 PM
So will this new-fangled method work on 3.2's also? Are the rocker arm ratios the same?
-Terry
Old 05-30-2006, 08:23 PM
Terry,
Yes, just did my '85 last month. The rockers are the same. I think you are good on all 911's up to the hydraulic lifters.
I jacked up the drivers side and did not drain the oil. Then did the passenger side. I lost less than 1/2 cup of oil.
I did remove the Catalytic converter for better access.
Simple and time saving. Only adjust the valves that don't pass the go-no go test.
Have fun,
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 05-30-2006, 09:05 PM
I used this method for the first time this weekend. I used all three - .002, .0025, and .003 to adjust and check. Since I adjusted the valves about one year ago, I used this time around to double check my work. I found four that were loose and none too tight. At first, I used just the .0025 and .003 feeler gauges, but then I noticed how close they were and I like to adjust on the tight side. So, I started using the .002 more. I really like this method because it takes the guesswork out of it, and no more fumbling with the .004 hooked gauge! End result? No more excessive tapping noise which drives me nuts! Okay, I'm really anal. Thank-you for this thread.
Old 06-12-2006, 11:44 AM
TCB TCB is offline
TCB's Avatar
This works!!!!!!!!!!!!!!!
I used the .004 hook gage twice then Doug's method to triple check my work and it is right on!! Next time (in a couple of years with the amount of milage I put on the old girl) I'll just use Doug's method!
Great thread
Terry
Old 06-12-2006, 11:56 AM
In the next couple of months, I plan on doing a valve adjust on my '87 Carrera. Call me too conservative, but I think "doing it" for the first time requires following the conventional method of adjustment, rather than measuring between the rocker arm and the cam lobe. Is my thinking a bit too puritanical, or should I take a walk on the wild side?
1987 Carrera 3.2
Old 06-12-2006, 06:24 PM
GrantG's Avatar
Do it both ways and prove to yourself how accurate the new way is (easy to check the cam/rocker clearance after setting the conventional clearance) - just takes another minute or so...
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 06-12-2006, 08:41 PM
TCB TCB is offline
TCB's Avatar
I agree. There will be lots of "bonding" with the car.
ASK ME HOW I KNOW
Old 06-12-2006, 08:48 PM
durn for'ner
livi's Avatar
Makes me wonder why Porsche did not come up with this technique in the first place. I mean they put the engine together, youŽd think some of their engineers would stop one day and go: " Hey, guys, it just dawned on me - why canŽt we adjust the valves like this ? Its helluva lot easier !!!
Hmmm....
Markus
Resident Fluffer
Carrera '85
Old 06-12-2006, 09:57 PM
Because Porsche is an auto company based on tradition. My guess is their engineers would claim the traditional adjustment method is superior, and it may be. Given the little time it takes, I intend to do it the both ways.
1987 Carrera 3.2
Old 06-13-2006, 01:17 AM
Because the German mentality is..."why make it simple if we can make it complicated ? ..."
I can say that with impunity since I have a German heritage !!
- Wil
Wil Ferch
Old 06-13-2006, 04:38 AM
Somatic Negative Optimist
Gunter's Avatar
What would the world be like without Porsche?
Would have to go BMW.
Or no German beer!
Shudder to think that we would be left with the chemical soup coming from certain breweries. Swill made for hockey-fans?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 06-13-2006, 05:24 AM
