theiceman's Avatar
sway bar bushing grease- what to use ?
I have my front sway bar out and am replacing all the rubber bushings. Does anyone have any recomendations on grease to use when putting the new bushings in ?
Thanks in advance
Old 02-04-2006, 05:11 PM
PP may have some specific to sway bar bushings. I put plenty of caliper grease in the bushings when I replaced mine.
Marv Evans
'69 911E
Old 02-04-2006, 05:22 PM
buster73's Avatar
I use Weltmeister silicon grease specially made for rubber bushings. High viscosity and will not wash out in the rain.
Regards,
Guenter
73.5 911T, mod
Old 02-04-2006, 07:11 PM
Early_S_Man's Avatar
Porsche Crest
Dow Corning 112 would be my recommendation.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-04-2006, 08:56 PM
theiceman's Avatar
So I guess sillicon is the way to go ..
Thanks guys ..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 02-04-2006, 09:47 PM
As I understand it, they are not supposed to be greased at all. You can use something like vaseline when installing the front bar into the bushing for ease of install. After that, if they squeek, that should tell you that they are worn out and you have steel rubbing steel.
Tony G
2000 Boxster S
Old 02-05-2006, 06:04 AM
fireant911's Avatar
Weltmeister recommends a 'good moly-lube' on their assembly instruction sheet. Annually, I give mine a refreshing via a meat flavor injector filled with this moly-lube - it works well with no disassembly required. All squeaks disappear.
Daryl G.
1981 911 SC - sold 06/29/12
Old 02-05-2006, 07:46 AM
Autobahn Garage
Sil-glide from NAPA
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 02-05-2006, 08:10 AM
theiceman's Avatar
Thanks for the input guys. I definitely the think the sway bars need some sort of grease because it has to move in the rubber mounts to be effective. I used some dielctric silicone compound to remount the bushings into the a - arms. Boy that stuff is slippery. SO I think I will use it when I remount the bar..
Old 02-05-2006, 03:41 PM
