RETIRED
Joe Bob's Avatar
The Mikey, Ingo and Dan tranny rebuild clinic....
So, I downshiftedd into to second....C L A N G.....my long hood comes home on a flat bed.....last night Ingo and I unbolted everything and did the pull this morning......Dan Byers was nice enuff to come over and help. He has pulled Stay Puff's motor and trans....many times now.....
But first....Daddy dootey.....
3.6 ON THE GROUND...
The offending 915.....
Ingo...."I'M, H E L P I N G"""""
2012 ML350 3.0 Turbo Diesel
Old 02-04-2006, 01:23 PM
RETIRED
Joe Bob's Avatar
Some purple people eater degreaser and a power washer.....
CLEAN AND TIDY!!!!!!!
Now the culprit.....
Old 02-04-2006, 01:27 PM
Semper drive!
rcecale's Avatar
HOLY *****!!!!!
'nuff said!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 02-04-2006, 01:31 PM
So...are we to understand that's not how that part is supposed to look... :-))
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 02-04-2006, 01:49 PM
RETIRED
Joe Bob's Avatar
I think a couple of spots with the MIG welder'll take care of that...
Old 02-04-2006, 02:11 PM
Grady Clay's Avatar
Mike,
Looks great clean.
Get that 915 gearbox apart asap. The pressure washer will force water past the differential (axle flange) seals and, if left for any length of time, damage the big tapered roller bearings that support the differential and ring gear. Of course it can get in all sorts of other places – past other seals, breather. The seals are designed to keep oil from leaking out, not high pressure water from getting in.
Please get it completely disassembled, hot, dry and re-lubricated. Water in hidden places in a transmission spells D-E-A-T-H.
That gear looks like part of a fixed 2nd gear. This transmission is going to need some VERY careful inspection. I’ll bet the bearings that support the input shaft and pinion shaft in the main differential casting are now slip-fit at best.
Please give us a blow-by-blow description of what you find.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 02-04-2006, 02:28 PM
RETIRED
Joe Bob's Avatar
Down to the differential.....appears to be ONLY the second gear set. Anyoen have a gear set?
83 SC 915 trans, need the HX gear set...
Old 02-04-2006, 02:34 PM
Unregistered
sammyg2's Avatar
Mikey, try this, it's really cool:
Take that t-shirt you were wearing in the photos and throw it in the washing machine with your wife's delicates. Oh boy you will both share a good laugh
Old 02-04-2006, 06:41 PM
RETIRED
Joe Bob's Avatar
Oh yeah.....that works...
Hey, what yer opinion....loctite or WEVO fix on the bearing race?
Old 02-04-2006, 06:44 PM
Unregistered
sammyg2's Avatar
How much clearance do yoo actually have? that will prolly be the deciding factor. If it's .0001" out of tolerance no biggie, if it's .002" then I don't think the loctite would last.
The only loctite I would use in this application is the green cylindrical lock stuff, caint member the number. i have used it on machinery in the past and it is decent stuff. Having said that, i figure it is a band-aid to cover up a problem instead of eliminating it, something you would do if you plan to sell the car is two years.
If it were me (and I'm glad it's not) I'd have one of my machinists at work bore it oversized about 1/4" and shrink in a 420 ss insert to restore the proper fit if it is opened up significantly. You have a full machine shop, right?
Granted that may be overkill and the loctite might last longer than that car, but it also might not.
Old 02-04-2006, 07:29 PM
RETIRED
Joe Bob's Avatar
http://www.wevo.com/wevoracecase.htm
Dunno how much tolerance.....it does pull out very easily...
Old 02-04-2006, 07:33 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Grady,
you are spot-on. The bearing race for the output shaft has about 0.2mm axial play in its seat I wouldn't even call this a slip fit anymore. It's a close fit at best - The loctite stuff looks good on paper at ambient temperatures. However, IMHO it would only be a question of time when the race gets loose again and the ring&pinion is going to grenade. I guess off goes the diff housing to get welded up and machined at Wevo.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
RETIRED
Joe Bob's Avatar
Downside....3 week turnaround on the WEVO upgrade....
Old 02-04-2006, 08:01 PM
Formerly bb80sc
Vipergrün's Avatar
Re: The Mikey, Ingo and Dan tranny rebuild clinic....
[/B]
Hope ya got some KY jelly there big boy
Wish I was there to help and hang with you evil 3......
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 02-04-2006, 09:07 PM
Acox914's Avatar
Send a message via AIM to Acox914
looks like fun mike...
i really didnt mean to bark second gear eveytime you let me drive it
-Aaron
"60% of the time, it works every time"
Old 02-04-2006, 09:46 PM
ischmitz's Avatar
The scope of the tranny rebuilt clinic was expanded a little bit to fix some nasty oil leaks on the 964. What a filthy mess. The chain housings acted like open drain plugs and there was a thick crust of oil and dust baked onto the engine under the fan shroud. At some point in the past there must have been a nasty oil breather hose leak or breather cover gasket leak. This will kill an engine since it effectively blocks airflow across the cooling fins of the heads and barrels. I belive its the main cause for barrels to go out of round. We had to scrape off most of that stuff before agent orange could be put to work. I am sure there won't be any weeds growing in Mike's driveway for a long time to come. Maybe there will be an oil field discovered in the future.....
Here is the long block after its sponge bath.
The chain housings were leaking like sieves. All gasket surfaces were heavily corroded. Mr. razor blade and evil sealant were used before putting them back on. Next the cams get timed:
Close but not good enough:
Ingo
Old 02-09-2006, 10:07 AM
Somewhere in the Midwest
MotoSook's Avatar
Looks like fun boys....
Dan...you were suppose to drop the drivetrain...not "dropping training." (glad to see you arn't still too busy to play with those too nuts )
Old 02-09-2006, 10:16 AM
DByers's Avatar
Ingo, Looks like you and Mike were working last night same as me. I got my WEVO trans mount in and al by myself!!!
Now get over to my house with those cleaning gloves and get to work on my bathrooms!
Souk, I was just there to help get the engine/trans out as Mike and Ingo had done all the prep the night before and with watching 3 kids my time was limited. Any way we just get the engine down and I can smell this "smell" and I look over at Mike and think "Damn man, you cant walk 2 foot over there!" Ended up up being Dylan with a little gift for Daddy.
(PS - luvn those monoballs! )
Dan Byers
Old 02-09-2006, 10:38 AM
MotoSook's Avatar
LOL....I might have thought Mike too! LOL.
Good luck on the rest of the work guys.
Old 02-09-2006, 10:46 AM
ischmitz's Avatar
'til almost 10PM - that's when the fumes of the brake cleaner and the agent orange finally got to us......
Old 02-09-2006, 02:24 PM
