Hendog's Avatar
rear defrost not working, but side mirrors are OK...
My rear defroster doesn't work but the side mirror defrost does work. They are acitvated by the same switch but does the relay in the engine compartment only act on the rear defrost?
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 02-09-2006, 02:27 PM
Did you first check your the defrosting element in your rear window to see if it had continuity and that the leads were still glued onto the grid?
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 02-09-2006, 03:55 PM
Hendog's Avatar
I haven't checked anything yet. Looking for a starting point and you just set it for me. Thanks java
Henri
Old 02-09-2006, 04:07 PM
kqw kqw is offline
Check your fuses...in the engine compartment.
Also, pull the rear deck and make sure that the grid connector is plugged in.
The Fox
Carrera
Old 02-09-2006, 07:29 PM
Break the problem in half....
If you have the two stage defroster, ie pull and twist, check to see if the two relays are being pulled. There are housed in the square box on the left sid of the engine compartment. If they are working them the issue is with the element. If not work back to the fuse and so on.
Cheers
Mark.....
Old 02-09-2006, 08:27 PM
Hendog's Avatar
Yep, it's a fuse all right. I've never yet replaced a fuse in the P-car and always looked at them wit a little trpidation because they look so odd. Are these readily available at the local auto store?
Henri
Old 02-09-2006, 08:31 PM
kqw kqw is offline
Yes, should be able to buy them from local parts store.
Also, be careful replacing the fuses in the engine compartment....That fuse block is live. Or you can disco the neg. terminal on the battery first.
The Fox
Carrera
Old 02-09-2006, 09:11 PM
