Project Update - learning to weld RSR style
So I got a welder and plasma cutter, and after some good advice on technique from Doug (DW SD) I was off to do battle on the car...
(don't blame Doug if the welds aren't clean, they were my own painful lessons!!!) I did the shock tower supports after putting in strips flat where the crossmember meets the body. I also put triangles under the front edge of the crossmember thanks to the thread Tyson posted earlier on supports. The front wheel well had a NASTY looking hole that had been cut for A/C lines that was all narly on the edges and bent up. I fit a piece in, welded the hell out of it, then grinded it flat so it'd look decent after paint. Next up is the front pan, I'm only halfway there on that project...
74 911 with '95 3.6l |
Looks like a VERY nice job! Congrats! Nice clean welds from my vantage point!
Sure was FUN playing with the plasma cutter the other day! Just don't get a digit or another extremity in the way of that puppy!! Good work! On deck circle: paint for the engine compartment and your nuclear certification (welding)!! Baby steps, mi amigo! Doug
1971 RSR - interpretation |
on deck circle...just no on deck changing :-)
Thanks for the kind words - welding is fun, and I'm definately proof that with the right tool, anyone can weld. Note to other pelicanites - close proximity to miller tools may cause increased desire to upgrade and spend money :-P
Nice job on the welding, especially if you are new to it! Looks great. That is on my list of things to do next week. What guage metal did you use and what machine are you using to weld?
Once again, nice job! Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
What?!?!
Very very cool!! I need to get a welder. There have been way too many times I've thought "Oh, I could just weld that up."
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross |
Thanks Jeff :-)
I used 11 gauge steel (=1/8") after Tyson mentioned that's what he used (thanks Tyson for that great thread!). The A/C hole I used 18 gauge steel which was pretty close (a little thicker prolly) to the inner front fender wall. The welder is a Millermatic 175 with infinate adjustment on wire speed and voltage. It runs off 220 power, and I used .023 wire for all this welding. Definately the infinate adjustment is KEY for someone like me who's never welded before. I don't know how to compensate as well as an experienced person if the settings are too far off (it seems easier to dial in the settings properly then compensate for incorrect settings). Good luck on yours! If you're doing the shock towers like I did, make templates out of paper or cardboard and cut the metal triangles with straight edges on the shock tower side. Then hold the metal piece in position and mark it a little with a sharpie to indicate where to grind it down. Use a bench grinder to shape the triangle's shock tower edge a little at a time until it fits really well. Take a LONG time to fit the trangles just right and the welding will be easy and come out better. Don't skimp on the fitment, it's way harder to make up gaps with welding than it is to take your time on the template. Oh, and when you get tired of welding, go drag knee for a while, and you'll be cured :-)
Is the weld bead only on the facing side? Is there access to lay a bead on the back side? Nice job though.
Sherwood |
You must be the only one that thinks the welds don't look clean. Not much looks better than shiny metal work on a 911. Well maybe Zoanas' avatar but not much else.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
Sherwood - the weld is only on the facing side on mine. I went and checked and it looks like there are a few sections where you might be able to fit the gun on the backside. There wouldn't be any visibility at all - welding blind. Maybe someone in the know could give an idea if it's needed. If so I can go try and give you the results!
Cool, I too have a 175, great welder. Thanks for the additional info!
Cheers
UFLYICU
Here, for comparison...
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Yup. Zoanas wins. Sorry.
Great job !! You certainly spent allot of time grinding and prepping the area. As with most projects prep is the key to success.Was the reason you made this modification.You have installed coil over shocks ? I've installed them (coil overs)on my 73' and plan a similar modification in the spring. Also is there room behind the plates to weld on the back side
More is better and too much is JUST enough |
cali74 - that is a great job. How did you get your engine bay down to (very clean looking) bare metal? Did you use paint stripper/grinder etc.... I'd like to know!
Thanks, Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
