Senior Member
Current draw problem
My car has developed a problem with battery voltage in the past few weeks. I started noticing it was cranking slower and slower. I also noticed my battery light on the gauge panel was glowing faintly. Finally I realized it was not the cold weather and that something was wrong because the cranking got slower and the batt. light got brighter. I checked the battery voltage with the engine off and got something like 11.79v. With the car running I got between ~12.4 and 12.6v.
I thought the alternator should be pumping out about 14+v's. I took the battery to the store where it was bought and ran a dignostic on it. They say the battery is fine. So I've got a current draw somewhere or an alternator that is not alternating. I replaced the alternator less than a year ago when the old one failed at the track. The battery is also about 13 months old. What could be the culprit here? A few guys at work said the starter could be the problem. Any ideas how to proceed with the diagnosis? _________________________________________ Is there a good way to test the alternator output? Is there a method to tracking down current draws?
-- Chief Architect and Mastermind, SCWDP |
Lee,
A system Voltage that low with the engine running ... is positive evidence of a bad alternator or Voltage regulator, and a sure case for pulling the alternator and taking it in for testing and rebuild! All of our cars need a big, expanded scale Voltmeter ... clearly marked with Yellow from 13.0 to 13.5 Volts, RED below 13.0 Volts & above 14.5 Volts ... and your case is just more evidence!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
12.6 volts measured when car is off= 100% charge
12.4V= 75% charge 12.2 V= 50% charge 12.0 V = 25% charge 11.7+ volts is a dead battery....... Car's charging system should show a range something like 13.3 to 14.5 V or so.... -Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
That will teach you to buy your battery at Victoria's Secret. As capable as they are, auto-electric just isn't their bag, baby!
Your Batterie is kaput, and your Lichtmaschine isn't putting out the right output! Prolly it's your Spannungsregler. Durn 993's with their complicated electrical systems. No fewer than forty-eight electrical motors in that sucka! Make sure every switch or subsystem gets regular exercise, and keep a spraycan of Corrosion-X handy.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Senior Member
lol, or door three... my positive cable to the starter motor had come loose. Tightened it back up and now everything is back to normal.
My father would smack me upside the head for this one. "Always start with the easiest fix and go from there."
Odds bodkins. The Porsche G_ds have surely smiled on you, by allowing you to find this before the wire came all the way off the terminal and did its impression of an 880-amp arc welder under your back seat!
Somebody, somewhere was upset about something. Is there another vehicle that is receiving more attention?
