Addicted to Racing
edbaus's Avatar
tool to remove diff bearings
Hi,
Does anyone have a source for puller that works good for removing the tappered bearings from either side of the differential on a 915.
Ed
Old 02-13-2006, 09:20 AM
I used a standard 2 jaw puller from Autozone- the teeth on the puller lags fit into the notched on the carrier. Only good if you are replacing the bearings- one slip and the are toast.
Mackskibum aka Dave Austin
'66 911 Work In Progress (#303734)
'85 911 Carrera
06 325XI
'05 Envoy XL SLT
Old 02-13-2006, 09:27 AM
Grady Clay's Avatar
This thread shows
”915 Repair - What tools needed to change carrier bearings?”
This is a sufficiently important operation (and you sometimes need to remove the bearings many times to get the settings correct) that a dedicated puller with the jaws ground to fit is worthwhile.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 02-13-2006, 10:04 AM
Just did this operation using a puller assembled out of a Snap-On puller set. Worked very well and puller jaws fit notches; also with the Snap-On set one can buy extra jaws if a custom tip shape must be ground to fit a particular job.
Old 02-13-2006, 11:38 AM
