adhesive for mounting "Carrera" badge
Just wondering what adhesive is best to mount a "Carrera" badge to the rear decklid? Thanks,
commandant of the compound |
I use Permatex Black Silicon Adhesive Sealant for these types of applications.
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
Don't these come with self stick adhesive on them? The ones I used did.
-Jeff
Jeff |
it was mounted previously with some sort of rubber cement.
![]() PS: If the answer is no - I would skip the adhesive and go with two 3" lag bolts. That should get r done... -Jeff
Jeff Last edited by NoLift911; 01-01-2006 at 04:42 PM.. |
They do come on a sheet of waxed paper and with a self adhesive on them. I have a couple from the bodyshop. To use them a second time requires a liquid adhesive of some sort. Or, you can get some film (not motion picture film) adhesive on a backing paper and painstakingly cut it out after applying to the existing adhesive. Then peel the 2nd backing paper and apply to the body of the car. This is the best way, but tedious.
3M makes several tape types that are ideal for this. |
You can use the auto grade, black double sided tape sold at autobody supply shops. Trace the Carrera text image onto the tape and cut a bit smaller with scissors. Apply to the clean back-side of the emblem and install.
As Milt mentioned there are many grades so make sure you specify the inteded use.
Warren & Ron, may you rest in Peace. |
Detached Member
3M double stick tape they make it wide enough for the entire height of the emblem.
Hugh |
exact location for mounting the badge?
Okay, does anyone know the exact location as in "centered and x inches below rear wing base"? I bought my car with a repaint where the PO never put a new badge on it.
IIRC...the deck with the Carrera tail did not have the Carrera script.
The Fox Carrera |
Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Will program for food
Mine came with the script and tail. I just removed it so I can eventually paint my car.
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
