Washer bottle mounting questions
I have a 72 911 T.
How does the washer bottle mount into the tub of the car? My old bottle which I'm replacing has a black bracket that is riveted (sloppily) into the bottle. 2 bolts then thread into this bracket from the bottom of the car. What is the correct way to do this? Anyone have a pic? |
cycling has-been
there should be a "W" bracket welded to the trunk floor, straight down from the hole in the lock rail sill. I think
I'll see if my pics capture the little guy.
73 911T MFI, 76 912E, 77 Turbo Carrera |
cycling has-been
the bracket is barely visible in the lower right corner in the shadow. (one of the tines is sort of in the light) this bracket only locates the bottom tab of the bottle to keep it from flopping around.
hope this helps Bill K
