Better DIY car, 3.0SC or 3.2C?
If you were looking to buy a car and part of your motivation was to do as much of your own work as possible would you look more at the 3.0 or the 3.2. Second part of the question, if you were also looking forward to doing performance and appearance (possible backdate project) mods to the car would you lean more to a 3.0 or a 3.2? I am sure the first part of the question will affect this as well but which car is generally less expensive to maintain? Thanks
Friend of Warren
They are both equally easy to work on and equally easy to modify although you can get more HP out of the 3.2 then the 3.0 for fewer dollars. For backdating the body they are the same to work on.
Kurt V No more Porsches, but a revolving number of motorcycles. |
IMO, not having to deal with CIS issues is a godsend.
Warren & Ron, may you rest in Peace. |
I was thinking that the chip tuning options on the 3.2 have to be pretty inviting
83SC black on black 01 Chevy S10 08 Buick Enclave |
I'd say the 3.2 for two reasons. 1 I've heard too much about working on CIS and wouldn't want to have to do it and 2 the engine compartment in the 3.2 is cleaner because the CIS on the 3.0 covers the whole darn engine with that unsightly airbox.
SC
![]() 3.2L
even the 3.2L with AC isn't that bad
Pretty much no tuning on CIS.
Silver 1980SC Euro coupe |
Light,Nimble,Uncivilized
I have a 3.2 and find DIY a piece of cake...I just pay John Walker cash.
Drago '69 Coupe R #464 |
EFI is easier than CIS
Both are DIY friendly.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Let's be honest....The two versions of 911's are pretty much indentical from the perspective of DIY....but I agree the various CIS permutations are really a band-aid compared to the set/forget nature of the DME FI system.
Sensors, however, for the DME can be a pain to properly trouleshoot...if they go bad. In balance, I would favor the DME cars..... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Fact or fiction.......SC are leaky-er that Cs. They tend to have more oil leaks that is.
From someone who is just completeing the conversion from 3.2 Carrera to 3.0 SC, the SC. If a 3.2 spends much of it's life around 6K rpm the stock rod bolts are going to give problems. My F class racer has just spun the number 6 rod bearing. Main bearings were fine. The 3.2 has smaller rod bolts. All 6 rod bolts were loose. The car is now a 79 Euro SC in G and will soon be an 83 Euro SC still in F again with more power more torque bigger rod bolts and less weight. They have identical chasis except for the thickness of the rotors and brake pads and corresponding caliper spacing. The 915 tranny changes a couple of gears but otherwise is the same. Fuel and spark are much easier to tune on the SC. The motor actually likes the headers.
Bryan |
Not much difference in DIY work between the two models. I'd rather have the DME not for chipping, but because it's a better system. CIS is not a trouble maker, though. Once it is set properly, it's good to go. But it does not offer the inherent trouble-free nature of a DME. Then again, as was stated, any DME problem will likely cause more in time diagnosing or sensor blah blah that needs replacing ...but that rarely happens from what I know. Assuming good overall condition of both cars, I'd get a DME if funds allow.
Edward
993: retired Trackmeister, now daily driver heaven 911SC: resident Trackmeister-in-progress |
It'll be legen-waitforit
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Id say the cars are remarkably similar. Id take the carrera, for the EFI is easier to deal with than CIS. At least that how I feel. Other than that, you can more or less treat the cars as identical.
They are super easy to work on.
95' Mercedes E300 Diesel (Azure+Sodalith Blue) 88' Porsche 911 Targa (FOR SALE) (Guards Red) |
I'll bite....Super Carrera or Carrera?
Superman or man? Supermodel or model? It is called super for a reason....long live SCWDP, David
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
I have a 3.0L SC hotrod, my dad has a 3.2L hotrod. All things equal I like the 3.0L midrange and pull better than the 3.2L. They both have SSIs, uprades etc and similar weight and suspension. But then again I have my timing and CIS set up very very well, so thats a none issue.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Well I just had to pull the engine/tranny from my '84 Carrera the other night with the help of a couple Pelican boys (jpinkert and Jess). My throwout bearing had seized. The extensive disconnections of the Motronic world were a royal pain compared to CIS or MFI. However the 3.2 does have more snap than my 3.0 in the SC. The cars are pretty similar up to the G50 introduction. YMMV.
Bill '72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride. |
