Porsche Crest Torque value
For a 77, what is the proper torque numbers for the heat exchanger to the muffler and the thermal reactor (or replacement piece)?
Thank you
Old 11-25-2012, 06:49 PM
Don't know for 77, but for 78-83, the torque numbers out of the Bentley manual for the muffler to the catalytic converter and cat to muffler are both 18 ft-lb. I assume these would be the same for the 77, but let's see what others might have to say.
Old 11-25-2012, 11:32 PM
Thank you 79_911SC
I had another person tell me 16.95 Ft-Lbs for both on a 77.
I think we are good.
Again, thank you for the quick reply.
P.S.
I know the Bentley manual is a very good book for 78 and newer. Do you think it is worth buying for a 77 or are there to many differences between 2.7 and 3.0?
Old 11-26-2012, 06:13 PM
Senior Advisor
James Brown's Avatar
wrench tight is just fine
08 Cayenne Turbo
Old 11-26-2012, 06:16 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You can contact Haynes or Bentley and they will look any torque specs not listed from the Factory Manual.
'85 Carrera Targa
PCA/POC
Thanks good to know.
Old 11-26-2012, 07:09 PM
