Wide Body Wheel Offset Q's
Yes, done the search. No help.
My 1980SC with turbo widebody came with some *&%* brand wheels and spacers. I'm looking for wheels for it that will eliminate the spacer/adapter deal. My thinking is 16x7's up front and 16x8 or 16x9 at the rear. Can anynoe tell me the correct offset for such wheels on a wide body??? |
the factory used 1 inch spacers in the rear and front useing 7 and 9 or 8s for the early cars. the 930s however had a 1 wider track on the banana arm so if adapting a non turbo set up (such as I am doing) then you can not really avoid running 2 inch in the rear and 1 inch up front. Unless you have custome made wheel and the folks that do that know what you need. Lindsey racing is a good start
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
I'm doing a slant conversion to my '86 and she's got BBS 8 & 10 x 16's with a 1" front and 1-1/2" rear spacers.
Contact Gary Stratton (407) 421-1911 for the correct wheel sizes and spacers. Steve E
My life is great! Prev. rides - 87 924GT, 86 Carrera, 69 Targa, 85.5 944 track car, 86 951 84 Triple Black 911 - Current |
Crotchety Old Bastard
That's a tough one.
I do not think there are any stock Porsche 16" wheels that will work in your application. The correct offset would be a 2" outer lip in the front and a 4" outer lip in the rear, pretty deep. Old school RSR wheels will work but they are 15", very expensive, and probably not what you are after. Here is a picture using stock 9x15 front and custom 12x15 rear: Here is a picture showing a "typical" offset wheel (requiring spacers) as compared to the custom or RSR offset: Here is a picture of the style of adapter you will need for most wheels to fit - 1" in the front and 2" in the rear. It'll cost you about $300 and is the most economical way to get you where you need to be:
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
For reference..ADAPTORS are devices as pictured, with their own mounting studs to be used along with the normal studs ( 10 fasteners / wheel)..as opposed to SPACERS...which use replacement longer studs thru the holes of the spacer......
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
That's just it, the car currently has 17x8 up front and 17x9 in the rear with 1" F & 2" R adapters.
I was hoping to get away from the adapters. |
here is a set that just went on a 86 widebody conversion
17x9 1/2 17x11 1/2 ![]() ![]() rear wheel next ![]() now the front ![]() no spacers used fit perfectly
Excell Racing Boca Raton fl |
Insert Tag Line HERE.....
Use CCW wheels like posted above, or these below.
No spacers used...
I went to CCW's site, they do not list anything smaller than 18" ???
Administrator
Lindsey Racing 2-piece Fuchs. Lots of grip for not too much green. These are 9.5x11x17 wheels with 275F and 315R tires.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
the black center wheels shown are 17
ssetek, i believe you.
That style is on the CCW site but they only list 18" and up ? Maybe they discontinued making 17" wheels, who knows. I do like those too ! |
http://www.ccwheel.com/files/wheelprofiles-model.php?id=classic i am a ccwheel dealer also if you need help
