Help!!! How do I find out what this Engine # Means
I have what I think is a 1971 911E Euro Model. It looks like many parts have been updated.
The Engine number is 6551315 The Engine Type is 911/44 My reasearch tells me that it is from a 1975 911S, but I don't know what the type code means. I would greatly appreciate any input, Thanks in advance. Best Regards, Louie
SHOPPING CART |
according to Bruce Anderson's book the 911/44 is a 1975 2.7 911S for California. specs same as 911/42 but with reduced power. 8.5:1 compression ratio with 160 hp @ 5800 rpm and 162 lb/ft torque @ 4000 rpm
the 911/42 is 175 hp @5800rpm and 175 lb/ft @4000rpm post the VIN so we can determine the year/model of the tub.
Tony G 2000 Boxster S Last edited by tonythetarga; 02-20-2006 at 09:31 AM.. |
Priced-out of Porsches.
According to Bruce's bible: 911/44
2.7 911 S engine for California (reduced power) 8.5:1 160HP @ 5800 RPM 167 Lb/Ft @ 4000 RPM Cheers, edit; Dang, 2 minutes late...
Mike SoCal |
Yes, the engine type code is congruent w/ a 1975 911S motor for delivery to California.
I believe a 1971 911E serial number should look something like this:
911120XXXX broken down it is: model = 911 year =1 for 1971 engine type =2 for 911E, 1 for 911T and 3 for 911S Body version = 0 =coupe; 1 =targa; 2 = Karmann coupe Sequential serial number = xxxx total is 10 digits for a 1971 model car
Tony G 2000 Boxster S |
911=911 model 1= 1971 model year 2= 911 E engine type 1=Targa body version 0433= sequential serial number
Mike SoCal |
As far as I can tell the only way to know for sure if the car was originally a Euro (at least in the earlier cars) is to go by original engine #, which in this case is no longer available.
Porsche may be able to sell you a Certificate of Authenticity and tell you original destination. I think they charge about $75 or 100 bucks for that.
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Additional Engine Info
Thanks Tony, Mike, J.K. !!!
I really appreciate the info!!! It is a very unusual project that I just bought. The VIN # is 911 121 0433 Blue Plates 833WEZ The Color Code is 1412-L (May Have been Special Order) It has a 1980 911SC Front Suspension 911S front Bumper The 1975 911S Engine has been rebuilt with MFI not CIS, the MFI t-Body has a Part Number of 911.101.312.1R (Possibly to do an RS Clone). It has an Alluminum Flywheel with 3 notches??? What do you guys think? Thanks, Louie
SHOPPING CART |
Pics...
SHOPPING CART |
