avendlerdp's Avatar
Carrera alignment specs?
Hello all. For those of you who spoke up on the "Longhood better then Carrera" thread I am posing some more questions about getting the Carrera to come alive. As I have stated before my Carrera understeers more then I want it to. I have heard that some of this is due to a change in the alignment specs from the earlier cars in order to make the handling "safer". Is there any merit to this? If so what do I need to do to loosen the rear of this car? I know that toe out in the front helps a bit but how much is right?
Thanks,
-Alex
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 02-20-2006, 08:30 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Standard stuff should work; softer (less air) up front, corner balance with more front bias, etc. Generally, you should be able to make significant changes with the tires alone on an optimally aligned Carrera.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 02-20-2006, 09:22 PM
Alex,
Just for fun, put a level on the front tire of your longhood and compare it to your Carrera. Which one has more negative camber?
Old 02-20-2006, 10:15 PM
